Rev limiter situations after crane hi-6s install ?
Old October 31st, 2011, 10:17 AM   #1
cornellm5 is on a distinguished road
Before I put the crane hi-6s on my 87 fox it didn't have a limiter I was revving it all the way up to 6k plus and now I put the crane hi-6s box on and now my limiter comes on at 5k sometimes and very few times it comes on at 6k I'm wondering did I activate the limiter or just something else is wrong and I have a a9l computer
Old October 31st, 2011, 10:22 AM   #2
nolife's Avatar
91GT, 88GT, 02GT
The stock limiter is 6250 and they all have it unless you have a chip or rpm extender attached. Your tack may be off as well.
Why the swap of ignition? The stock ignition is very reliable and very capable.
Old October 31st, 2011, 12:48 PM   #3
EscortSportage's Avatar
1989 Mustang GT 5.0
Never heard that before, i always heard and thought the stock ignition is weak and csnt keep up with higher revs
Cage
Maximum Motorsports
Sparco
QH/BE
Nitto
"a huge bad azz motor is nice untill you have to turn or stop"
Old October 31st, 2011, 02:56 PM   #4
I figured the ignition box would help me and why Before the box my car was reving to however high I wanted it to go
Old October 31st, 2011, 03:20 PM   #5
nolife's Avatar
91GT, 88GT, 02GT
No, the stock ignition is more reliable than anything in the same price range aftermarket, including the dizzy. It can handle 6250 with no problem. Anything above and YMMV.
To look at it another way.. When you add an MSD or something similar, you are disconnecting the coil source wires from the computer and adding your aftermarket ignition to it, the output of that new ignition box goes right back to the coil (or an aftermarket one). You aren't replacing anything at all, only adding more between it. All of your existing stock ignition system is still there and being used. Maybe you swap out the coil as well but either way... The aftermarket boxes add new capabilities like multispark discharge under a certain RPM, a seperate tack output, soft start, windowing, retarding, adjustable rev limiters (although the stock fuel pull one will still activate at 6250 regardless of your setting on your box) etc. Any of those may be required for your specific tune or application but it does not make it any more reliable or more capable and the power gains and fuel economy claimed for some of them is questionable in my opinion although some people claim they see a few more low end HP and MPG.
If you need something above 6250 (although you still have to defeat the factory rev limiter) or advanced features of an aftermarket box, go for it, other than that, you are wasting your money and adding something else to the mix that can fail. A lot of people buy them and install them so they must be doing something useful right
I have the factory coil and an MSD box (6BTM) but I only needed it so I could retard my timing under boost.
Old October 31st, 2011, 03:39 PM   #6
nolife's Avatar
91GT, 88GT, 02GT
What mods do you have? If you getting anywhere close to a true 6250 rpm (not going by the factory tach which can be over 1K off) on occasion, you are shifting way to late.
Old October 31st, 2011, 04:05 PM   #7
ryanw's Avatar
1991 Ford Mustang GT
Hey Nolife do you get your car tuned ? The reason I ask is I'm going to supercharged my car next year and I wasn't sure if retarding the timing under boost can be programed into the computer or do I need to go with msd for some thing like that.
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old October 31st, 2011, 04:19 PM   #8
fogged306's Avatar
89 GT
Yea you can adjust your timing for boost with a chip or a tuner.
Old October 31st, 2011, 04:27 PM   #9
nolife's Avatar
91GT, 88GT, 02GT
Yes, My crap is old school. No chip just an adjustable FPR, adjustable FMU, and adjustable boost retard. Makes decent power but I am always listening to the engine and looking at FP
Old October 31st, 2011, 06:00 PM   #10
I have a 306 with ported Windsor jr heads tf track heat intake lt headers 238 cam .550 lift 112 ls and all the rest of boltons
Threads Similar to: Rev limiter situations after crane hi-6s install ?
do not buy from crane cams fastforded Vendors 2 December 26th, 2008 03:02 AM
CHE K-Member brace & Torque limiter install...? SUHLeen 2005 - 2010 27 September 12th, 2008 02:24 PM
Crane Cams blackhavok 2005 - 2010 128 December 15th, 2007 05:48 AM
Crane Cams ZoomZoomMFer 96-98 21 September 3rd, 2007 02:22 AM
Crane stage 2?? kmjsmith 2005 - 2010 9 July 5th, 2007 12:20 PM
