#21 | |
Instead of tuning with sway bars to reduce or eliminate under or oversteer couldnt you adjust springs to get a more neutral setup. ![]() ![]() Just for curiousity.
![]() Sig by Tricep |
#22 |
Priest of the Car Gods
Sure you could change your spring rate. But for anything outside of a racecar, to have spring rates high enough for proper roll control will be too harsh for most people on the street.
And I lied - moving the A-arm forward WILL affect steering: it'll add caster, which will cost you some steering angle.
#23 | |
#24 |
1989 Mustang GT 5.0
I want to know what a coilover spring rate thats unbarable for street
Im running 400 f and 300r. And ive heard that thats to stiff for street. And i disagree. I love it
Cage Maximum Motorsports Sparco QH/BE Nitto "a huge bad azz motor is nice untill you have to turn or stop" |
#25 |
1989 Mustang GT 5.0
I just met a drifter with a 240sx. Running 1200 springs up front and 1000 in the rear. And he drives the car everyday. I think that is a lil much
But he needs those springrates for drifting...
#26 |
I disagree, you don't need to be that stiff. Hell, most guys I know that drift 240s do so on cut stock springs.
#27 |
1989 Mustang GT 5.0
I guess its his personal preference the. I bet he has no body roll
#28 |
1989 Mustang GT 5.0
Prolly no tire grip either hahah
#29 |
tru' dat.
#30 |
1989 Mustang GT 5.0
Sooo since we r on the topic of swaybars. Have u ever heard of weldig a bead or two with a mig welder to stiffen the bar even more...im never doing this but i thought that was interesting
#31 |
I haven't heard of welding beads, but I have heard of people stacking bars
#32 |
It would b easier just to run an adjustable rear bar. That way you can fine tune ur setup.
#33 |
But it's WAY cheaper to just get a half-dozen hose clamps and pull another rear bar out of the junkyard, lol.
#34 |
1989 Mustang GT 5.0
Well on the adjustable from mm. Thats where i started i wanted mm front and rear bars...600 dollars later. Im like. Ill try junkyard finds first
Cheap and kinda fun
#35 |
i think Griggs makes an adjustable front sway bar.
#36 |
Yeah, ask Jazzer about that one, hahaha.
#37 |
1989 Mustang GT 5.0
Grigg is priceyyy!!!!!
And im sticking with mm. Ill have the entire catelog soon
#38 |
1998 Mustang GT
So has anyone stacked bars on a mustang? Can't find any non import info on it
#39 |
1989 Mustang GT 5.0
Thats gotta be some super low budget thing, think about all the different stock bars from 79 to 04. Then aftermarket on top of that, id think there would be no really good reason to stack bars other than having no money...
#40 |
Try the GRM boards.
Threads Similar to: Rear swaybar question
| what type of REAR swaybar to get? | Fetalinjury | 94-95 | 0 | February 19th, 2011 08:55 PM |
| BMR Rear swaybar | pear0119 | 2005 - 2010 | 5 | October 5th, 2009 02:41 PM |
| Performance Differential Cover hits rear swaybar *HELP* | PapaSmurf | 99-04 | 5 | December 9th, 2008 08:43 PM |
| rear swaybar... | 97Cobra | General Tech | 4 | July 30th, 2007 09:24 PM |
