Help with plan of attack
Old October 31st, 2011, 05:26 PM   #1
brought_pain will become famous soon enough
I got an 83 mustang and would like some ideas/oppinions. I've taken the car to 3 places to have the chassis checked and all 3 say no signs of damage. No computer or measurements, just eyeballed.
My plan is go through most of the car and fix it up. 5 lug conv., new motor, new trans, new diff, new interior, 91-93 fender, sub frame connectors, etc. This car is a daily driver. I was planning a back to front, bottom up approach. I feel a bit flustered thinking about where to begin now.
Old October 31st, 2011, 05:33 PM   #2
ryanw's Avatar
1991 Ford Mustang GT
I'm not sure. But I'd do some research to make sure your wheels will still line up in the center of the wheel wells before you go spending money on the newer fenders. I'm guess you want 17in wheels ?
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old October 31st, 2011, 05:36 PM   #3
ryanw's Avatar
Why did you have the sub frames checked out was it wrecked ? If you went through the effort of taking it to 3 different shops to have it looked at, why didn't you just take it to one place and have it checked on a frame machine ?
255 fuel pump,
3:27 gears
Old October 31st, 2011, 05:46 PM   #4
YEAH, different, bigger RIMS. Believe it or not I couldn't find anybody with a "frame machine"...
I also seem to find the bend-you-over-sorts, so wether I'm not fixing stuff that ain't broke, or not paying for stuff I don't want/plan on upgrading, its been a bit of a hassle.
I had the chassis checked because I don't want to strengthen a tweaked chassis...
Old October 31st, 2011, 11:08 PM   #5
horsepowerjunkie's Avatar
1989 Black LX---Turbo
horsepowerjunkie will become famous soon enoughhorsepowerjunkie will become famous soon enough
Any body shop that's been doing business in the past 20 years should have a frame machine. It sounds like you took your car to shops with some lazy employee's.
89 LX Black, Boss 331, C4,T76BB, FAST EFI
82 Capri RS,89 5.0 HO,Comp XE266,TW 170,T5,etc.
73 Dart Sport 340, 410ci Bracket Brawler
72 Demon 340 4-speed 1 of 1667
01 Ram Quad Cab
03 Grizzley 660
Old November 1st, 2011, 01:07 AM   #6
2001 True Blue Bullit
Roadrashjr is on a distinguished road
Yeah.. Make sure you take it somewhere reputable. Preferably if you know of a good mechanic around. I took my car to get my strut checked out and the guy at les schwab tried to convince me my front axle was bent.. lol
2001 Bullitt
Currently Stock
Old November 1st, 2011, 06:56 AM   #7
EscortSportage's Avatar
1989 Mustang GT 5.0
To start: FL subframe connectors, grab an 8.8 out of a newer fox, grab hubs,spindles,brakes and axles from a 1994 or 1995 only mustang theres ur 5 lug and rear wheel disc setup, while ur under there call maximum motorsports and order the 5 stainless steel brake hoses. Very nice pieces i might add i just put em on myself, ur gonna need a bigger master cylinder and a brake proportion valve. They reps at mm will tell u all the stuff u need.
Lower ctrl arms
Cage
Maximum Motorsports
Sparco
QH/BE
Nitto
"a huge bad azz motor is nice untill you have to turn or stop"
Old November 1st, 2011, 07:00 AM   #8
1989 Mustang GT 5.0
Lower torque box reinforcements.
Junk your quad shocks
Bump the timing up to 15 degrees
Junk smog pump and charcoal canister
Cage
Maximum Motorsports
Sparco
QH/BE
Nitto
Old November 6th, 2011, 02:33 PM   #9
Driving it back from an alignment shop, it started losing power. Stopped at a light I see a puff of smoke come out. So I pull down a back street, lift the hood, and the engine is smoking and oozing black stuff out of the valve covers and intake manifold.
...fast forward past the waiting over 2hrs for a tow......
Mom asks me to drive her to get her vitamins...sure mom...
Stopped in traffic we get rear ended... my hat flew off my head into the back seat...it was a pretty solid hit.
She calls her insurance guy and explains what happened. He tells her to have her car checked by a place. We get there, the guy looks it over and explains she should have the chassis checked by a computer there...
The end.
MM xl subs should be here tomorrow. thanks though, I honestly appreciate all the advice(especially the advice I agree with)
...a bent front axle? Sounds bad...could you get by without it?:...
Threads Similar to: Help with plan of attack
attack of the dog WilltheThrill Videos 2 March 4th, 2008 04:06 PM
attack of the dog WilltheThrill The Clubhouse 9 March 4th, 2008 01:25 PM
Attack of the key 90Stang 2005 - 2010 11 January 2nd, 2008 09:44 PM
The plan of attack for my 79 built351w 5.0 Mustangs 2 October 11th, 2007 06:07 PM
