B303 or E303??
Old May 28th, 2007, 10:15 AM   #1
92mustanglx is on a distinguished road
B303 or E303??
hello, my friend has a 1990 Mustang 5.0 5sp and he wants to install a aftermarket cam. Either the B303 or the E303. Hes looking for something with a nice lopy idle and a good midrange power increase. So far mods include cold air intake, fresh 19lbs injectors, headers, h pipe, flowmaster, king cobra clutch and 4:10 gears. He plans on putting a set of 351w or gt40 heads (ported and polished)FRPP roller rockers and a GT40 intake. Out of these 2 cams which one would fit this application the best???
Thanks
302, EdelBrock Upper and Lower Intake, GT40 Aluminum Heads, E303, Shaved&Balanced Crank w/bearings, BBK Induction, SuperChip, BBK Shortys, BBK Off Road HPipe, Flow Masters, 4:10, 2" Eibach Drop Springs, 17x9 Chrome Cobra R, 245/45ZR17
Old May 28th, 2007, 10:28 AM   #2
Big timin' in a small town
Drick's Avatar
2004 FX4 F150, 86 GT
Once the heads and intake go on you could get away with the E303 cam but I would upgrade to 24lb injectors and also for heads I always here great things about the twisted wedge trick flow if your open to head suggestions im putting the twisted wedge heads on my 331 stroker build
FX4 Crew
Crew member #1
Don't take anything I say to heart, I don't try to come off as an asshole. It just happens
Old May 28th, 2007, 10:47 AM   #3
ok, so your saying e303 with new heads, or b303 with stock heads.. i understand that putting on new heads with either cam would be the best idea, but could he get away with the b303 cam and his stock heads?
Old May 28th, 2007, 01:37 PM   #4
out of the 2 cams, which has the most lopy idle to it? I have a E303 in mine sounds good, but ive never heard a B303, just heard alot about them
Old May 28th, 2007, 01:41 PM   #5
I have a similar setup just waiting for my car to get out of the trans shop for me to put my topend on...I am going with the B cam.
Ported GT40 heads and cobra intake
1.7 RRs
73MM MAf
24# inj.
65mm TB
LT, o/r H, flows dumped
4:10s
I was talking with TMOSS over on corral and i told him my setup and he said the B cam would work great with those heads.
For stock heads, you will want to upgrade the springs. I dont think the stock springs will hold a B cam
[SIGPIC][/SIGPIC]
[B][U]MM Sapper Squad[/U][/B]
Old May 28th, 2007, 03:26 PM   #6
86er's Avatar
may I ask why yall keep goin to the letter cams?
If you look around, theres about 10000000000000000 better cams, that will work much better than those out dated cams
Just a truck
Old May 28th, 2007, 06:47 PM   #7
TENGRAM is on a distinguished road
x2
89 GT t5 3.73
www.my5oh.com/
Old May 28th, 2007, 06:51 PM   #8
ok well which cam would you suggest?
Old May 28th, 2007, 07:04 PM   #9
Blown5.0's Avatar
Blown5.0 is on a distinguished road
If your going to do all that you listed, Id buy Race Susp 1st, your going to be all over the road with no traction..
89 Mustang lx 5.0
11.5 Compression
Edlebrock 150 dry kit
1.70 0-60ft 11.20 @124
Old May 28th, 2007, 07:04 PM   #10
1993 Mustang GT
Haggis13 is on a distinguished road
Send a message via MSN to Haggis13
I'd toss the alphabet cams out the window, and go with a Comp Cam, or a TFS Stage 1 cam. I'd also change the heads before I put a bigger cam in the car. The stock heads SUCK at moving air.
Bart
93 Black on Black GT
Kenne Bell S/C
GIVE 'ER!
Old May 28th, 2007, 07:59 PM   #11
jam77's Avatar
1987 Mustang GT
jam77 is on a distinguished road
B303 or E303??
Im not sure the specs but a freind of mine has the holley system and the cam that came with the kit sounds sweet and that car moves.
Old May 29th, 2007, 01:35 AM   #12
usmcsawgunner's Avatar
1993 Mustang GT
13.2 @98.54
usmcsawgunner is on a distinguished road
Send a message via Yahoo to usmcsawgunner
finally someone else who thinks like me....
Old May 29th, 2007, 08:46 AM   #13
the car is alreay lowered 1.5" with kyb shocks, and a strut brace. we already thought of that lol
Old May 29th, 2007, 06:38 PM   #14
86er's Avatar
upper and lower control arms, the stock ones will make you cry when you place them next to an after market piece.
Just a truck
Threads Similar to: B303 or E303??
B303 Cam acmillr 5.0 Mustangs 32 November 9th, 2007 09:10 PM
B303 cam homebrewed 5.0 Mustangs 21 March 9th, 2007 12:07 AM
b303 cam with 1.72rr's bigbadtalontsi 5.0 Mustangs 5 January 16th, 2007 06:36 PM
E303 Cam jtillery 5.0 Mustangs 20 December 31st, 2006 03:31 PM
Timing degrees for E303 cam 95StangSVT 5.0 Mustangs 0 June 22nd, 2006 11:37 PM
