1990 GT
unknown
KenneBell 1.8 tips?
Before I get blasted for it, I KNOW THE KB IS NOT THE POPULAR CHOICE FOR A FOX! Ok, backstory... Stock 1990 GT with 70k on the odo. It is my DD and for the next few years will not see a track. Got a line on a KB that I decided not to pass up, it's the 1.8 which is fine for me. On to the tech, what is the recommended gaskets to use prior to mating to the lower as well as between the throttle body and the SC? What is the general consensu on fuel, 42lbs (big but room to grow), 255 LPH pump, and the matching MAF meter? The blower is going to come with the KB Fmu, but I havent found much supporting that setup. Lastly, regular plugs 1 step cooler gapped to 30?
Any tips tricks or guidelines you guys with some experience have for me? |
1991 Ford Mustang GT
id get the car tuned with the larger injectors and forget about using the fmu.
1990 GT
unknown
That's what I was thinking, is 42 too large? I want to go big now so I don't have to do it again later once I start building the block. Any suggestions on the gaskets?
42 should be fine . the tuner will program those size injectors/fuel curve into the cars computer. Just make sure its tuned before you drive the car.....you dont want to blow some thing up
take the lower intake off and port it to get a really nice added hit in power - I have a how-to in the Tech Doc section here: EECTuning.org • Index page
88 GT Vert 5spd, 3:73 gears, Explorer intake/65mm TB, Explorer Ps, Manley race 1.85/1.55 valves, 1.7/1.6 stud rockers, stock cam +4 degrees, MAC Jet-Hot coated shorties. 277RWHP/330RWTQ www.fastlanecars.com http://tmossporting.0catch.com/
1994 Mustang Cobra
how much hp are you looking for down the road and have you thought about running e85?
94 Cobra 351w .040 over DSS Forged Pistons Scat Rods TFTW Heads 2.205 Intake 1.62 Exhaust Trick Flow R Intake 750Cc RC Injectors Aeromotive A1000 pump and Reg Boost Brothers Turbo Kit
1990 GT
unknown
I'm not looking for anything out of the blocks capability, honestl I think it will just be the KB for the foreseeable future. As it stands I have too many mouths to feed (toys not kids) so it will be atleast a year or so till I crack back into the cars guts. Why do you ask abou e85?
Threads Similar to: KenneBell 1.8 tips?
| options with my 95 kennebell GT | SCHROEDTER | 5.0 Mustangs | 25 | March 25th, 2011 06:36 PM |
| Kennebell Horsepower | orangemonster | 2005 - 2010 | 23 | March 29th, 2008 02:33 AM |
| What comes with Kennebell kit? | 20gtvert03 | Modular Mustangs | 2 | January 28th, 2008 10:11 AM |
