howards TC
Old November 5th, 2011, 09:49 AM   #1
1FAST6's Avatar
1989 LX hatch
15 and change
1FAST6 is on a distinguished road
Question
howards TC
getting ready to install a Howards adj. timing set. Is it OK to install 2 degrees advanced on a stock 1989 5.0
1987 Buick Grand National
1989 Mustang LX 5.0
Both BLACK
Old November 5th, 2011, 11:55 AM   #2
Sinatra's Avatar
Sinatra is on a distinguished road
Advancing the timing past TDC runs the risk of excessive spark, which will cause back fires and sometimes knocking in the combustion chamber. Be careful with Ignition Timing because the wrong formula will permanently damage your engine.
Old November 5th, 2011, 12:29 PM   #3
fogged306's Avatar
89 GT
He's talking about cam timing, not ignition timing. And stock ignition timing is 10* BEFORE TDC and advancing it means you go more degrees before TDC. To go past TDC is retarding the timing, not advancing it.
OP, you won't run into PTV issues if you advance the cam 2* if that's what you're asking.
Old November 5th, 2011, 12:49 PM   #4
1FAST6's Avatar
1989 LX hatch
15 and change
Will it help with performance or should I just install at 0 deg.? Just figure while I'm in there if i can get more performance then I will.
1989 Mustang LX 5.0
Both BLACK
Old November 5th, 2011, 01:34 PM   #5
fogged306's Avatar
89 GT
I can't give you any real world experience with that personally. I just know that I've run more duration and more aggressive ramp rate cams than stock in my old 306 that had stock style flat tops and advanced them 4* with enough PTV clearance. Try corral or yellowbullet if you don't get anyone on here that can give you some empirical data on performance.
Old November 5th, 2011, 04:30 PM   #6
horsepowerjunkie's Avatar
1989 Black LX---Turbo
horsepowerjunkie will become famous soon enoughhorsepowerjunkie will become famous soon enough
If you don't check actual timing events with a degree wheel, its kind of a guessing game anyway.
89 LX Black, Boss 331, C4,T76BB, FAST EFI
82 Capri RS,89 5.0 HO,Comp XE266,TW 170,T5,etc.
73 Dart Sport 340, 410ci Bracket Brawler
72 Demon 340 4-speed 1 of 1667
01 Ram Quad Cab
03 Grizzley 660
