T-stat Housing
Old November 5th, 2011, 08:35 PM   #1
88gt1320's Avatar
1995 mustang gt
12.37@114
88gt1320 is on a distinguished road
T-stat Housing
I have a 351W based Professional Products Huricane intake in my 95 gt and was wondering if any has had any issue with t-stat housing lining up this manifold? I have a leak around the water hose as they are not mating correctly.
Old November 5th, 2011, 09:36 PM   #2
fogged306's Avatar
89 GT
Use RTV instead of a gasket.
Old November 6th, 2011, 11:29 PM   #3
2001 Ford Mustang Cobra
fox_body_stang is on a distinguished road
Yeah if you don't get it completely cleaned off the gasket will never seal right, but like was said use rtv.
2001 Ford Mustang Cobra---1993 Notch
Colorado Car Forum
Bringing Horsepower Junkies together!!
Old November 8th, 2011, 04:06 PM   #4
88gt1320's Avatar
1995 mustang gt
12.37@114
It wont blow out right? I can feel with my finger that the water outlets dont line up. The T-stat housing its seems to be a little larger than the manifold.
Old November 8th, 2011, 04:21 PM   #5
fogged306's Avatar
89 GT
Depends on how large the gap is, but chances are, no it won't blow out. I actually filled in my entire bypass inlet on the housing with RTV and it hasn't blown out yet after about 1000 miles of driving. I don't run a heater so it was a cheap fix until I get another housing, and it works, so I doubt a small gap is going to give you a problem if you apply it correctly and let it cure.
Threads Similar to: T-stat Housing
T-stat Housing? 88gt1320 94-95 0 November 2nd, 2011 07:47 PM
Mustang running hot 180 T-Stat vs 195 T-Stat? 96StAnG5.0 94-95 7 May 19th, 2011 02:48 PM
160 stat??? BIGDADDYKANE 99-04 8 December 26th, 2009 12:55 AM
Need help stat!!!!! jcarter8432 5.0 Mustangs 8 February 18th, 2009 11:50 PM
t-stat njstang 99-04 8 August 31st, 2008 04:45 PM
