Need help!! Starter problems
Old November 7th, 2011, 01:19 PM   #1
87poonstang is on a distinguished road
So a few days ago my car wouldn't start. It would sometimes start and sometimes not. Then it just stopped starting at all. When I turned the key over it just made this click sound. So my first thought was the starter solenoid. So I replaced that and it still does the same thing, just a click sound. And I even tried connecting the starter Solenoid with a screwdriver to get it started and it does not do anything, no spark or anything. I'm stumped where to go next. Thanks
Old November 7th, 2011, 01:40 PM   #2
brought_pain will become famous soon enough
battery?
Follow the wiring and check the itegrity of the wires and circuts.
Also pull the dipstick and check the texture of the oil for metal(rub it between your fingers, look close at it with different light).
Old November 7th, 2011, 02:35 PM   #3
But my car will push start just fine. I'm going to take the starter in later today and get it tested
Old November 7th, 2011, 07:04 PM   #4
fogged306's Avatar
89 GT
Most likely a dead spot in the starter. Take a hammer and give the starter motor a few whacks while someone cranks it with the key and see if it fires up.
Old November 8th, 2011, 01:51 AM   #5
Jims88gt is on a distinguished road
Originally Posted by brought_pain View Post
battery?
+1
Old November 8th, 2011, 04:25 PM   #6
I took the starter in and they tested it as good...
Old November 8th, 2011, 05:04 PM   #7
ryanw's Avatar
1991 Ford Mustang GT
Test the battery and alternator. And check all your grounds
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old November 9th, 2011, 02:24 AM   #8
1988 Mustang 5.0 LX
12.48@118.27
ddarkslayer is on a distinguished road
autozone tests are junk
Threads Similar to: Need help!! Starter problems
starter problems, please help 408w Fox 5.0 Mustangs 12 March 7th, 2010 08:10 AM
Starter Problems 96gtstang&V6 96-98 13 May 11th, 2008 06:01 AM
starter problems brokebp417 5.0 Mustangs 4 March 12th, 2008 01:51 AM
Starter problems Arrest Me Red 5.0 Mustangs 10 June 12th, 2007 12:31 PM
starter problems Please help OTreborO General Tech 1 July 12th, 2006 11:29 AM
