AC/Smog Delete questions..how to??
LinkBack (1) Thread Tools
Old November 7th, 2011, 05:11 PM   1 links from elsewhere to this Post. Click to view. #1
5.0doktor18's Avatar
1993 Mustang LX 5.0
5.0doktor18 is on a distinguished road
Question
i have a 93 5.0 lx. just upgraded new mishimoto radiator and electric fan. looking to clean up engine compartment and squeeze out few more hp that this "gives" you ppl say but anyway.. im sure there are other people on here that have done the smog/AC delete to their car..my questions are what exactly do i need to get to do this? Does anyone have a step by step how to do it for either? any pictures would def. help. thanks
Old November 7th, 2011, 07:40 PM   #2
WildStang88's Avatar
1988
N/a
WildStang88 is on a distinguished road
I'll be doing this to my current motor as well, so I'll be interested to what people give for advice. I think it should be pretty straight forward though, de-pressurize the AC system disconnect the lines etc. Some people use the eliminator brackets while others bypass that even and go straight from the water pump to the alternator and tensioner to the power steering.
1988 Mustang GT, Grey, BBK CAI, MSD Distributor and Wires, BBK Equal Length Shorty Headers, BBK O/R X-Pipe, Flowermaster Super 44's, 15x8 275/50/15 Nitto's-Rear, 15x5.5 155/80/15's BFG's-Front
Old November 7th, 2011, 09:47 PM   #3
1993 Mustang LX 5.0
ya i think it is pretty much, i just thought it would be worth a shot puttin up a thread. just wana double check make sure im doin it right or make sure im pullin off the right stuff lol
Old November 7th, 2011, 10:23 PM   #4
ryanw's Avatar
1991 Ford Mustang GT
if your still runing your FACTORY CATs they will burn up or get cloged with out the smog pump, pump air into them. If you have after market cats or no cats at all then you will be alright in getting rid of the smog pump.
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old November 7th, 2011, 10:27 PM   #5
1993 Mustang LX 5.0
i have an BBK h-pipe on my car so that should be ok. do you guys how to go about de-pressurizing the system tho? never thought of that..there a certain way or just disconnect it?
Old November 7th, 2011, 10:29 PM   #6
1988
N/a
You'll have to have a shop do that. Don't go just disconnecting it, not a smart idea lol
Old November 7th, 2011, 10:36 PM   #7
ryanw's Avatar
depressurise the A/C system ? if thats what your asking you have two choices, take it to a auto shop and they will recover the freon, or two wich by law is illegal, but you take out the schrader valve out ( or push it in and let it leak out) or just loosen one of the fittings some where in the a/c system, in a matter of a min or two the system will be empty. But again i must state that this is against the law. so should you do this, do not do it in public and make sure your in a ventilated area, do not breath it in.
255 fuel pump,
3:27 gears
Old November 7th, 2011, 10:40 PM   #8
1993 Mustang LX 5.0
im trying to look it up how to but everyone keeps sayin you need a special tool..why cant you just disconnect or cut the hoses..what exactly is under "pressure'? sorry trying to learn..
Old November 7th, 2011, 10:41 PM   #9
1993 Mustang LX 5.0
ohh ok thats interesting never knew that. thanks
Old November 7th, 2011, 10:47 PM   #10
1988
N/a
Refrigerant is whats under pressure. Think of an aerosol can, you got your liquid and pressure inside... without it having any pressure nothing comes out. Refrigerant circulates through the system because of the compressor (and pressure). I hope I didn't confuse you.
Old November 7th, 2011, 10:48 PM   #11
ryanw's Avatar
yes to do it right( legally) you need special tools. You would need A/C gauges, a vacuum pump, a recovery machine, and a recovery can.
255 fuel pump,
3:27 gears
Old November 7th, 2011, 10:53 PM   #12
1988
N/a
http://www.2ndlifetools.com/images/2...e%20duvals.JPG
http://www.jsjjt.com/usr/20/upload/p...2708435397.jpg
Old November 7th, 2011, 10:58 PM   #13
ryanw's Avatar
the freon under pressure is a liquid, it get pumped by your compressor to the E-vap coil. ( e-vap coil is under dash) where it get sprayed in like a fuel injector, inside the car. air passes over the e-vap coil blowing cold air into your car.,the freon warms up and becomes a gas. it then retuns to the condeser coil (its the radiator looking thing in front of your radiator) where your cars engine fan helps to remove the heat from the freon, it then get pumped back into the compressor, and the freon is compressed back into a liquid...then it starts all over again
255 fuel pump,
3:27 gears
Old November 8th, 2011, 08:38 PM   #14
1993 Mustang LX 5.0
another question..how do you go about plugging the spot on the intake manifold and then i hurd there is one on the heads? can you just block them off with a bolt or..? thanks
Old November 8th, 2011, 08:48 PM   #15
ryanw's Avatar
are you talking about the cross over tube on the back of your cylinder heads ?
255 fuel pump,
3:27 gears
Old November 8th, 2011, 08:59 PM   #16
1993 Mustang LX 5.0
yes and there is one that is on my intake also on the right side. i have TF street heat intake
Old November 8th, 2011, 09:01 PM   #17
1993 Mustang LX 5.0
i just looked it up and i dont believe its that. i could be wrong. ive just read up on ppl having to plug a bung on the back of the heads when they do the deletes
Old November 8th, 2011, 09:06 PM   #18
ryanw's Avatar
yes there are two holes you will have to plug if you take the cross over pipe off( the cross over pipe is not what its really called, but i cant remember what else to call it. and most people know what your talking about when you say that). its easy to take off, its two small bolts that you remove, and under the pipe there are two lare holes, just plug them up and your done. cant remember the size bolts though that you will need to plug it up. maybe some one else can post the answer to that
im drawing a blank on any thing having to do with smog on the intake other then the EGR valve
255 fuel pump,
3:27 gears
Old November 8th, 2011, 09:22 PM   #19
1993 Mustang LX 5.0
ok that helps ill have to take a closer look at it tomarrow durning the day. maybe snap some pictures
Old November 9th, 2011, 07:58 AM   #20
1995 Mustang GT
mcglsr2 is on a distinguished road
I recently removed the smog pump on my 95 Mustang, it was pretty straight forward. Here's a link to a PDF how-to with pics:
http://www.allfordmustangs.com/techarticles/Smog2.pdf
It was done on a 94/95 5.0, but should still be applicable to your 5.0. You also might need a different bolt size for the back of your heads. Mine was 9/16 like the instructions said, but I had to clean out the threads from all the carbon build-up before the bolt would even thread in.
For my mid pipe, I just got a huge bolt that would fit the hose on the little pipe thing that ran to the smog stuff, cut the hose down a little, put the bolt in there, and used a worm gear clamp on it. I haven't had any issues.
I'm running a non-catted mid pipe, by the way. Oh, and that cross over pipe is called something like the thermactor pipe or air injection pipe or something like that. And I didn't have to remove any smog stuff from the intake, the only "connections" were to the air pump and mid pipe, though you WILL have to plug two vacuum lines, I used two small bolts and zip ties for this.
Lastly, I used a new serpentine belt rather than a $70 dead pulley on a bracket. I tried 3 belt sizes, 90.5", 90.8" and 91.0". 90.5" was just too short, it maxed out my tensioner and made it chatter, 91.0" was too long, and 90.8" was just right. YMMV with the belt sizes - I kept everything else (PS, AC, alt, etc). If you are removing the AC, you'll obviously want a smaller size.
As for codes, I now get two new codes during KOER: 311 - (AIR system not working - Single, Right or Rear HO2S - Air Injection) and 314 - (AIR inoperative, Left or Front HO2S - Air Injection) which makes sense, since the AIR stuff was removed. I also periodically get a check engine light, usually after cruising for a while - the computer is trying to turn on the AIR stuff and it's not working (obviously) so it throws a MIL for about 30 seconds, then it goes away. It doesn't affect driving at all.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/238825-ac-smog-delete-questions-how.html
Thread Smog Pump delete/Belt reroute | Mustang Forums for All lFord Mustangs | BoardReader This thread Refback December 31st, 2011 07:53 PM
Threads Similar to: AC/Smog Delete questions..how to??
Smog & A/C Delete whitefox89 5.0 Mustangs 42 December 31st, 2011 01:14 AM
Smog/AC Delete Questions lakefrontlivin 94-95 5 June 20th, 2010 11:56 PM
I'm doing a smog delete and have questions 95GTSTALLION 94-95 5 February 26th, 2009 01:36 PM
AC and Smog Delete Questions kpoirot 94-95 7 September 25th, 2008 02:48 AM
AC Delete and Smog Pump Delete triplethreatt77 5.0 Mustangs 14 December 24th, 2007 06:09 AM
