car shutters
Old November 7th, 2011, 09:15 PM   #1
Rippedoff's Avatar
2006 Mustang GT
Rippedoff is on a distinguished road
car shutters
I noticed my car did this the other night when my exhaust clogged blew a gasket not really sure whats wrong with it. When I down shift my car shuttters and makes a stalling noise. I also noticed my car is idles at 1g. it takes it awhile to idle back down when i take car out of gear (sometimes). My car always sound weird during down shift. My motor sounds weird with the clutch disengaged sometimes. To make the motor sound normal i have to push clutch in. I also noticed a ticking noise but not extremely loud. Its hard to get third gear in sometimes and fifth gear sometimes makes me think i need some gear oil maybe? This all happen when i drive car twenty mins or more some morning none of this is going on besides the down shifting sound. That has happen before my new exhaust problem
Old November 7th, 2011, 10:19 PM   #2
ryanw's Avatar
1991 Ford Mustang GT
Id try running your codes first...you do not need a scanner to do this. just google how to check codes on a fox body mustang and it will exsplain how to do this. basicly it makes your check engine light flash, you count the flashes and then look that number up and it give you an idea of whats wrong.
Id also try cleaning your mass air meter. and check you TPS sensors (voltage). you can learn how to do this buy going to the top of the 5.0 page under useful links , or some thing like that. never mind ill just post the link
Cleaning The Mass Airflow Sensor
Mustang idle surge and base idle reset
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Threads Similar to: car shutters
New Member Transmission Shutters slighttly when letting off gas over 35mph TX77 V6 Mustangs 37 November 8th, 2010 10:29 PM
AOD Shutters While Stopping shwagy357 5.0 Mustangs 1 March 25th, 2006 06:42 PM
