wont run after rebuild
Old November 8th, 2011, 12:27 AM   #1
allhotmustang is on a distinguished road
hello all. i have a question i have a 91 gt convertible i just had rebuilt and the engine was bored 40 over keith black forged pistons, total seal rings, gt40 heads ported and polished,lower intake ported and polished,kenne bell 1.5, the person i had build this engine was a terrible builder he timed the cam wrong, messed up wiring etc. etc. the engine will start sometimes but will die on its own when compression is checked before startup the cylinder pressures are between 125psi and 115psi when the engine dies its at 115psi to 100psi, could someone please help me im spending alot of money in this engine on diagnostics.
Old November 8th, 2011, 12:28 AM   #2
Imran's Avatar
01
Imran has much to be proud ofImran has much to be proud ofImran has much to be proud ofImran has much to be proud ofImran has much to be proud ofImran has much to be proud ofImran has much to be proud ofImran has much to be proud of
Hmmm....
well... ya did something wrong...
Old November 8th, 2011, 12:35 AM   #3
ya i know the mechanic that worked on this has cost me unnecessary money, any help would be greatly appreciated
Old November 8th, 2011, 01:24 AM   #4
ryanw's Avatar
1991 Ford Mustang GT
do the wet?dry test. that will tell you if its the rings or the valves.
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old November 8th, 2011, 09:25 AM   #5
fogged306's Avatar
89 GT
Did you pull the timing cover and degree the cam? Having it off can cause low compression readings like that.
Old November 8th, 2011, 10:06 AM   #6
the mechanic didnt do the wet dry test, and i know for a fact he didnt degree the cam he just tried to align the timing gears,what is the procedure on performing the wet/dry test?
Threads Similar to: wont run after rebuild
car wont start OBD II wont read. ECU? ForestGRN_Ghost 99-04 7 September 14th, 2011 11:38 AM
Buy a built T-5 or rebuild with g force rebuild kit? Cloud Nine 5.0 Mustangs 17 February 21st, 2011 02:25 AM
Help with 4r70w...wont fully engage into gear after accumulator rebuild. freefallin2000 99-04 11 August 21st, 2010 10:44 AM
Where To Get A Good T5 Rebuild Kit That Wont Kill My Budget? e3sean 5.0 Mustangs 56 February 20th, 2010 11:34 AM
