battery relocation with second battery
Old May 29th, 2007, 04:23 AM   #1
onewinner is on a distinguished road
now that i solved the first issue i must ask another question. i'm running a 2000 watt amp and a compressor for air suspension up front aside from numerous other electrical mods - like flame throwers . the question is what way do you think is the best way to run a second battery without seeing my pride and joy go up in smoke ??????
Old May 30th, 2007, 12:30 PM   #2
fogged306's Avatar
89 GT
Just run it in parallel with the first battery, Ground it at the same spot if you want and I would recommend an isolator. You can run the car without it fine but they are nice because you can run all of your extra electronics of the second battery and not worry about it straining your primary system. If you are going to get an isolator get the real ones that are essentially giant diodes, NOT the ones that are just a solenoid, they are worthless. You will know the difference by the price. The ones that are the diodes will cost you a lot more, but you get what you pay for. You can fuse the wire going to the second battery if you want. Sometimes I don't do it but its a good idea to do it anyway, 150amp fuse or breaker will be fine because you are only using the connection to charge the battery.
Threads Similar to: battery relocation with second battery
Hatchback battery relocation pyrofenix 5.0 Mustangs 7 June 26th, 2007 03:40 AM
battery relocation onewinner 5.0 Mustangs 13 May 29th, 2007 04:17 AM
Battery Relocation 90Stang 5.0 Mustangs 11 April 16th, 2007 08:31 AM
Battery Relocation 98vortech Modular Mustangs 0 September 14th, 2006 07:23 PM
Battery relocation quiestion? Mustang8719 5.0 Mustangs 13 May 2nd, 2006 12:08 AM
