Possible newb trouble
Old November 10th, 2011, 01:37 PM   #1
boss302man is on a distinguished road
I recently picked up an 86 5.0 as a project car and didn't poke around the engine to much. The only thing i cared about was that it ran and drove. It has a squeal on start up so I figured it was the alternator. Well under further inspection, I noticed it does not have a belt tensioner. I bought a belt tensioner and pully. but I'm not quite sure how to bolt it up.
I noticed while searching for parts that some tensioners came with a bolt. But of course this one didn't.
Since I am currently going to mechanic school, I have access to Alldata and Mitchell, but they have no instructions on tensioner install.
So I guess my questions/theories are:
Where you would but the 3/4 drive to relieve tension, the bolt goes on the opposite side which is connected to a bracket, which is connected to the alternator? If anyone has any close up pictures or a detailed instruction on how to go about putting one in that would be great.
Thanks a lot for the help and I hope I made myself clear.
Old November 10th, 2011, 09:49 PM   #2
MakeFast's Avatar
1995 Mustang GT
MakeFast is on a distinguished road
Im sorry for doubting you, but there is no sense behind removing a tensioner. If it were missing the belt would have soo much slack it wouldnt be able to be installed? The tensioner goes between the alternator and smog pump (if applicable) and I dont believe its a 3/4 drive hole, its probably a 3/8 or a 14-15mm wrench right onto the bolt holding the pulley on. Double check.
Old November 13th, 2011, 12:20 AM   #3
Believe me I know its pointless to remove the tensioner... I would never have done that. But the belt does have slack, so he might have at least installed a shorter belt.
The tensioner should be a simple bolt on, but my main question is what size bolt holds the tensioner on? what grade, thread, bolt, head size is it? Any help is greatly appreciated.
Old November 13th, 2011, 06:57 PM   #4
gripthenboost's Avatar
91 Mustang GT
1991 sliver GT
gripthenboost will become famous soon enough
maybe wrong belt?
Threads Similar to: Possible newb trouble
Newb Transmission Trouble droptop93GT 5.0 Mustangs 7 February 11th, 2008 09:39 PM
Newb, With Newb Questions fs308 5.0 Mustangs 41 January 13th, 2008 03:15 PM
Newb from MD ndnboy New Members Introductions 19 January 10th, 2008 08:29 PM
Newb! i'm a newb with a 69 grande boostedzx3 New Members Introductions 16 December 9th, 2007 09:44 PM
newb r1ray New Members Introductions 7 February 6th, 2007 12:10 AM
