'89 Mustang Convert
4cyl to v8 Conversion advice.
I have an '89 4cyl convertible that I'm looking to put a 302 in.
I got the car when I was 14, my uncle did all the paint work. I drove it a little bit before it started having tranny problems. I always intended on converting it to a v8 I just never did. Now I have the time and money to do it (11 years later). Im looking for advice that will make the conversion as simple as possible. I've found a bunch of motors on craigslist, but the fact that I can't hear them run bothers me. Id rather spend a couple more bucks to make sure it runs. Ideally Id like to find a whole donor car. If I do is there any certain year that works best? I want the motor to be fuel injected and the car is automatic so id like to keep it automatic just to keep it simple. any input is appreciated! |
'89 Mustang Convert
'89 Mustang Convert
'89 Mustang Convert
AAAAAHHHHHHHHHHHHHRRRRRRNNNNNNNGGGGGEEEEE.....
A 91-93 would be my wish. Just swap everything over. Also, from what I've read, convertibles benefit greatly from sub frame connectors. Something about the chassis flexing more. I have no personal experience to back it up or anything other than internet talk. |
1994 Mustang Cobra
If your looking I have a ecu/wiring harness/coil packs/electronic dist out of an 01 explorer 5.0
94 Cobra 351w .040 over DSS Forged Pistons Scat Rods TFTW Heads 2.205 Intake 1.62 Exhaust Trick Flow R Intake 750Cc RC Injectors Aeromotive A1000 pump and Reg Boost Brothers Turbo Kit
1990 Mustang GT
Good lookin fox.
![]() 1990 Mustang GT |
1991 Ford Mustang GT
Don't get an engine from a 1986 mustang. It was the first year of fuel injection but the engine sucked. It has some thing to do with the pistons and heads, if I'm remembering right.
Threads Similar to: 4cyl to v8 Conversion advice.
| 4cyl to 8cyl conversion wiring harness questions | sharkbait | 5.0 Mustangs | 0 | June 1st, 2010 01:38 AM |
| 4cyl conversion wont start | rasalibre | 5.0 Mustangs | 25 | October 21st, 2009 01:56 AM |
| conversion problems 4cyl 2 8cyl h.o efi | mustang mikey | 5.0 Mustangs | 1 | February 13th, 2007 08:16 PM |
| 2.3l to 5.0l Conversion Advice | jtillery | 5.0 Mustangs | 6 | January 9th, 2007 05:51 PM |
| which computerfor my 92 ?(4cyl. conversion) | gixxer1 | 5.0 Mustangs | 3 | May 21st, 2006 01:16 PM |
