vortech v3 oil change see some grit in oil
LinkBack (1) Thread Tools
Old November 11th, 2011, 11:00 AM   1 links from elsewhere to this Post. Click to view. #1
87superduperstang is on a distinguished road
ok so today i changed my super charger oil and it is the 2nd oil change ive made since it was new i have only around 6000 miles on it and i noticed in the old oil there is a little bit of looks like tiny tiny flakes maybe 6 tiny pieces is this normal to see sometimes
Old November 11th, 2011, 01:30 PM   #2
'88 Mustang GT
DigitalDC89 is on a distinguished road
Send a message via AIM to DigitalDC89
im not a supercharger expert or anything, but was it making an bad noises prior to the oil change? the flakes could be bearing material or something. but if the propellers were painted or coated in anyway before assembly, it could simply be flaking off. im basing all of that from a quick google search...
'02 Mustang GTm Convertible - N/A Cammed Daily
'88 Mustang GTm - 1/4 Mile Build - 750rwhp Project
'97 Saturn SL2m - Ex-Nitrous Build - Back-Up Daily
Old November 11th, 2011, 04:54 PM   #3
no noises works perfect and sounds normal
Old November 11th, 2011, 05:10 PM   #4
ryanw's Avatar
1991 Ford Mustang GT
Are you using the stock pulleys ? The reason I ask is to see if your over spinning it.
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old November 11th, 2011, 05:25 PM   #5
im pushing 16 pounds at 6000 rpm, but it is the si trim and i usually am only pushing it to 5000-5500 max so prob more like 14 lbs. my thought was maybe some junk got through the air filter ? not sure if that makes any sense though
Old November 12th, 2011, 03:50 AM   #6
1SICK5.0VERT's Avatar
modded 95 gt vert
1SICK5.0VERT is on a distinguished road
sounds to me your internals are breaking apart slowly but surely. are you running 16# on a stock bottom end?
BLACK ON BLACK 95 GT VERT FULLY CONVERTED TO A 95 COBRA AND MODIFIED WITH ALOT OF GOODIES AND A BB SINGLE T67 TURBO KIT. 526.14RWHP 496.00RWTQ @6PSI. RAN OUT OF FUEL @5500RPM PROJECT CAR AKA MONEY-PIT LOL!... TUNED BY GEORGE @ AKRON HP.
Old November 12th, 2011, 06:58 AM   #7
The Big Spoon
jessemachone's Avatar
88 5.0 5 Speed Notch <><
never fast enough
jessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of light
If you are getting stuff from the intake (dirt) into the oil, you have bigger problems than you think.
If you bought the unit brand new and this is the first time you are seeing the flakes, I would continue use provided that you dont notice any changes. (noise) It may just be some extra flashing that was missed during the manufacturing process.
Get in touch with the manufacturer and send them pics or a sample of what you found and see if it is anything worth worying about.
Black Stang Crew
Originally Posted by 302Army187 View Post
old 5.0's are like a box of chocolates.......... never know what your gonna get
Old January 10th, 2012, 11:58 AM   #8
i forgot to update this , but i found out that it was just some dirt and debres on the drain hose of the supercharger that fell in the bucket when i drained the oil haha man i feel stupid .
Old January 10th, 2012, 02:31 PM   #9
ryanw's Avatar
I how did you come to that answer
255 fuel pump,
3:27 gears
Old January 11th, 2012, 10:01 AM   #10
well the drain hose hangs down far to the bottom and it had alot of dirt on it so i wiped some off and could see it looked the same as what was in the oil and just to be sure of it i drained the oil again and watched the oil kind of run down the lip of where some grit and debre was and it made sense to me . what led me to do this initially was i took a piece of the debre from the oil and rubbed it with my fingers and it just disintigrated like road grime or dirt would.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/239155-vortech-v3-oil-change-see-some-grit-oil.html
Thread vortech v3 oil change see some grit in oil | Forums at Modded Mustangs | BoardReader This thread Refback May 1st, 2012 09:36 PM
Threads Similar to: vortech v3 oil change see some grit in oil
True Grit DegralDan The Clubhouse 1 January 23rd, 2011 02:09 PM
VHT/150 grit disaster in drivers side tail light. freefallin2000 General Car Care & Detailing 13 September 30th, 2010 01:25 AM
ever heard of this?....vortech v5 impeller change 78mach1 5.0 Mustangs 2 October 9th, 2008 01:06 AM
Oil Change with the new Vortech MeZ 99-04 1 April 15th, 2008 12:01 PM
vortech pulley change 2001bullitt 99-04 3 January 19th, 2007 12:09 AM
