87 fox dyno results ?
Old November 11th, 2011, 05:48 PM   #1
cornellm5 is on a distinguished road
My car just made 281hp & 291tq at 5k something is stopping it from going past that and dyno guy said its a ignition problem and my cam peaks at 6600rpm so after I get it fixed what could my rwhp be ?
Old November 11th, 2011, 05:50 PM   #2
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
That's going to be real tough to say without knowing any mods. Unless you have some real good heads, and intake, it won't make power at 6600 RPMs.
./___ _ ____ ___ \.
( ]]] _ _ O _ _ [[[ )
\_ o _ _____ _ o _/
|___| ......... |___|
Old November 11th, 2011, 06:15 PM   #3
I have Windsor jr heads port and polish and trickflow track heat intake
Old November 11th, 2011, 08:29 PM   #4
ryanw's Avatar
1991 Ford Mustang GT
what else...need more info.....injector size, fuel pump size , cam, cubic inch of motor ect ect ect......
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old November 12th, 2011, 12:57 AM   #5
306; 24lb injectors 73 c&l maf 190fp 238/238 .550 112 lsa 4.10 gear longtube headers track heat intake 1inch spacer and Windsor jr heads port and polish
Old November 12th, 2011, 03:44 AM   #6
1SICK5.0VERT's Avatar
modded 95 gt vert
1SICK5.0VERT is on a distinguished road
are you running an adjustable fuel pressure regulator? if not that would be the first thing i would address. also are you running a hotter coil then stock? if not you need to get one asap. i would check your plugs too while you are at it. my ford racing book says that the 24# injectors are good to 326hp n/a at 85% duty cycle, and your fuel pump is rated at providing 540 n/a hp to the flywheel so you should be good there.
BLACK ON BLACK 95 GT VERT FULLY CONVERTED TO A 95 COBRA AND MODIFIED WITH ALOT OF GOODIES AND A BB SINGLE T67 TURBO KIT. 526.14RWHP 496.00RWTQ @6PSI. RAN OUT OF FUEL @5500RPM PROJECT CAR AKA MONEY-PIT LOL!... TUNED BY GEORGE @ AKRON HP.
Old November 12th, 2011, 09:11 AM   #7
91cobra5.0's Avatar
98 Cobra
at that point its gona be the little things that get you past. like what plug wires, wt coil, what size rockers and if they are rollers.. the list goes on and on
Old November 12th, 2011, 09:21 AM   #8
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
I'd say you won't see much more than the numbers you already put up.
./___ _ ____ ___ \.
\_ o _ _____ _ o _/
Old November 12th, 2011, 02:13 PM   #9
I have 1.6 comp roller rockers and I have the coil that came with my crane hi6s box
Old November 12th, 2011, 02:15 PM   #10
And yes I'm running a bbk fpr
Old November 12th, 2011, 07:17 PM   #11
This is my dyno results
http://mail.aol.com/34561-111/aol-6/...wMail&partId=1
Old November 12th, 2011, 07:18 PM   #12
Thats my dyno result it couldnt go past 5k it kept backfiring..
Old November 12th, 2011, 11:31 PM   #13
nolife's Avatar
91GT, 88GT, 02GT
What is the condition of the springs and are they the right ones for your cam? Also, go back to the stock ignition coil and remove the Crane box and compare.
Old November 13th, 2011, 11:45 AM   #14
brought_pain will become famous soon enough
+1
Think about 30-36# injectors and check the timing.
Threads Similar to: 87 fox dyno results ?
Dyno Results hippojumqer 99-04 62 October 22nd, 2010 09:40 PM
Some dyno results Mustang RacR94 4V / SVT 7 July 29th, 2009 02:25 PM
Dyno results 03SuperchargedGT 99-04 35 March 4th, 2009 10:12 AM
Got my car dyno results Kemp"Da_Chit"08GT 2005 - 2010 19 March 1st, 2009 02:06 AM
Dyno results anyone rxnodoze02 2005 - 2010 5 December 25th, 2007 12:25 AM
