87 5.0 runs warm not cold?
This 87 mustang 5.0, got a rebuilt bored .30 over racing everything in the engine. Here's the problem, it'll only start when warm, i mean it'll start when it's cold if the throttles half way open but it'll just die. Ya have to start it 2 or 3 times to get it to warm up, when it's warm it's fine, he's replaced every F'ing sensor, he thinks it's the cam, the motor was rebuilt 2 years ago and has almost never been used due to this problem.
1990 Mustang GT
is it throwing any codes?
![]() 1990 Mustang GT |
1991 Ford Mustang GT
check your fuel pressure
1995 Mustang GT
My 95 gt is doing the same. My fuel pressure is running about 28-30psi. What should it be? And how do u adjust it?
Didnt mean to hijack ur thread just having same exact issue and didnt want to start another thread on it. |
#5 | |
if you have the stock reg, as far as i know they cant be ajusted, you would need to buy an after marke ajustable one
1990 Mustang GT
My mustang did this, and it turned out we forgot about the act sensor when we did the rebuild. The gt40 intake doesnt have a spot for it on there so its just sittin in the valley for now until i decide if i want to do anything with it
No.
I would but it's not my car, I'm thinking about buying it. It's cool man, turns out the timing is off on this motor too, it's definitely almost a brand new motor, it's 2 years old but it looks brand new sounds smooth when it runs fine but the timing is off also, it revs up and down a little, it seems the idle is too high and at random times it just looses rpm's then goes back up, sometimes it stalls out. Some times as in every couple minutes if you leave it running, but when your driving it won't stall. |
Threads Similar to: 87 5.0 runs warm not cold?
| motor warm or cold for tune up | 04gtvert | 99-04 | 6 | December 23rd, 2010 04:02 PM |
| Anything above 1/4 throttle, car barely runs. Cold weather? | N. Dave | 5.0 Mustangs | 4 | November 6th, 2010 12:49 PM |
| Runs better cold but crappy when warm | sharkbait | 96-98 | 5 | November 23rd, 2009 09:35 PM |
| My 5.0 runs like poop when its cold. Please Help | noyz25 | 5.0 Mustangs | 20 | November 9th, 2008 12:01 PM |
