No power
Old November 12th, 2011, 11:04 PM   #1
dah
1991 mustang gt
dah is on a distinguished road
No power
Hey guys i recently built a motor for my 91 gt. The bottom end is stock it has gt40p heads, explorer intake, lt headers, 70mm throttle body, 24lb injectors, 1.7rr, and a e303 cam. The car isnt running much faster than it did with the factory motor. I talked with a mechanic and he said the throttle body might be to large so i tried my factory one and it didnt change much. Any suggestions on how to make it faster with what i have would be greatly appreciated thanks in advance
Old November 12th, 2011, 11:20 PM   #2
ryanw's Avatar
1991 Ford Mustang GT
do you have a matching mass air flow sensor calibrated to the 24lb injectors ? What is your timming set at ?
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old November 12th, 2011, 11:27 PM   #3
dah
1991 mustang gt
yes its a c&l 76mm and timing is at 14
Old November 12th, 2011, 11:34 PM   #4
Chris951's Avatar
1991 mustang 5.0
Chris951 is on a distinguished road
Fuel pressure? Were the heads rebuilt? Worn out heads/valve springs will make a very big difference in performance. My last fox had over 200k on the motor and i swappeud the heads out for some fresh rebuilt e7's and it picked up ALOT of power. Just a suggestion.
Old November 12th, 2011, 11:58 PM   #5
dah
1991 mustang gt
idk about the fuel pressure but the guy i bought the heads from said he rebuilt them, he said they were trick flow springs but i dont no how to tell
Old November 13th, 2011, 10:54 AM   #6
brought_pain will become famous soon enough
What about the fuel rails? Are they from the old setup? Check those for obstructions.
How much faster is it? That combo should be close to 300hp vs stock 225.
Check the fuel lines too, maybe change the filter...
I've seen some kind of Goo/gum stuff that plugs filters. I got a lot of it out of an inline can and seen it in a clear, see through filter. The stuff seems to not get pushed through even though its liquid like. It doesn't break down in gas either.
Old November 13th, 2011, 11:14 AM   #7
ryanw's Avatar
C&l maff meters are known to have problems. that would be the last brand of maff id ever use. im not playing, they suck, Try putting your stock maff and 19lb injectors back in, to see if it gets better
255 fuel pump,
3:27 gears
Old November 13th, 2011, 07:40 PM   #8
gripthenboost's Avatar
91 Mustang GT
1991 sliver GT
gripthenboost will become famous soon enough
When you mean its not much faster? What difference did u feel at all? Thats a nice peppy combo. With your combo you should be running alot better up top around 60-120. Are you running stock exhaust and cat?
Old November 13th, 2011, 08:36 PM   #9
dah
1991 mustang gt
The fuel rails are stock. ill have to check them out when i swap back to the 19lb injectors and stock mass air. As far as power its alittle better than stock but not anywhere close to what i would have thought. the exhaust is bbk longtubes and a o/r x pipe.
Old November 13th, 2011, 08:47 PM   #10
ryanw's Avatar
check your fuel pressure, it should be 39 psi with vacuum line blocked off/ engine running, and for the hell of it check your codes, it only takes 5 min to do
255 fuel pump,
3:27 gears
Old November 13th, 2011, 09:14 PM   #11
dah
1991 mustang gt
could the o2 sensors have anything to do with the low power? i just remembered the guy who helped me put the motor in didnt plug them in because the wires were to short.
Old November 13th, 2011, 09:28 PM   #12
ryanw's Avatar
get those o2 sensors pluged in
255 fuel pump,
3:27 gears
Threads Similar to: No power
Help no power pony2stallion 99-04 24 May 12th, 2011 06:34 AM
Is there a Brak kit to go from non power to power? steelcityfan29 Classic Mustangs 15 January 6th, 2011 03:57 PM
how much power can i expect with these upgrades?or what can i do for mad power? muscletang420 99-04 34 October 30th, 2010 10:54 AM
1998 power window motor has power then installed its dead?? crabbymaddy V6 Mustangs 2 September 19th, 2010 07:26 PM
how much power kratos2250 5.0 Mustangs 1 March 5th, 2007 10:49 PM
