OVER Heating Issues......
View Poll Results: overheating
overheating 2 66.67%
overheating 1 33.33%
Voters: 3. You may not vote on this poll
Old May 29th, 2007, 04:08 PM   #1
94mustangp.o.s's Avatar
94mustangp.o.s is on a distinguished road
Hi my names austin, i'm recently a new member here at modded mustangs!!, i have a 1994 mustang gt convertible. recently i've had problems with it over heating. the car warms up slowly and then when driving it on the freeway the gauge spikes up a little, but when i proceed to try to cool it down by turning on the heat the gauge tips over further, and when i turn the heat off the gauge goes down alittle then spikes right back up..?
any idea's on what this could be or cause this issue??
i've replaced the thermostat myself with a 180 degree thermostat ...
Old May 29th, 2007, 05:57 PM   #2
JBIGBOOTSY's Avatar
1990 LX hatch
At first I wanted to pick overheating, then I thought, mabe overheating is the andwer. Finally, after hard thought ,I have decided on overheating.
Old May 29th, 2007, 06:57 PM   #3
all motor
SALIV8's Avatar
92 coupe
9.94@136.40
SALIV8 is on a distinguished road
yeah i think ur right bootsy... prolly overheating
Old May 30th, 2007, 05:09 PM   #4
jpalm is on a distinguished road
man, the cooling systems on these things are sooo good, I live in south alabama and seldom have problems, but the times i have it was the usual suspects; thermostat, low coolant (check when cold), bad fan clutch, obstructed radiator. also, don't put just water in it either.
good luck
jpalm
Old May 30th, 2007, 06:16 PM   #5
IcantDo55 is on a distinguished road
Just for a test, next time it overheats put on the A/C and see if it cools down.
-Mike
Link to My Site
Want to Play Some Pool???
Stroked and Blown!
Old May 31st, 2007, 06:48 AM   #6
neverfastenough1's Avatar
Yeah, because if the car doesn't get any cooler with the a/c on, you might want to get that fixed too. Wait, maybe he meant the water temp getting cooler. Never mind. Booty, it was a hard choice for me too, but like you, i went with the overheating. I would check all that usual stuff that was mentioned up there somewhere.
Old May 31st, 2007, 10:16 AM   #7
hey thanks everybody for your help.. sorry, i really didn't understand what the "poll" thing was but yea, does anybody know anything about really high oil pressure???lol..... my car is pegged out and im just wondering of some possible causses...
on the bright side.. just put in my March Peformance ram air kit
next week "pauls high performance" is installing King Cobra Clutch and ECU tune... ecu tune i guess picks us 25-30 hp and 20-25 tq... has anybody had these numbers or is it just B.S.??
Old May 31st, 2007, 10:17 AM   #8
Old May 31st, 2007, 12:03 PM   #9
Ok. In a 1994 Mustang they had electric fans that are thermostatically controlled. They either go on when engine is hot or default and go on when the AC is turned on. Its common for the thermostatic switch to go bad and not turn the fan on when the motor gets hot. To test we turn on the AC defaulting the fan to run and cool the car. If the car cool off when AC is running there is a problem with the thermostatic switch or relay.
-Mike
Link to My Site
Stroked and Blown!
Old May 31st, 2007, 03:49 PM   #10
tording92lxnotch is on a distinguished road
Unless you have some serious mods done like heads/cam/intake and supporting mods I really don't think the ECU tune is going to matter all that much. I doubt you will see those numbers.
92 notch--Shorty headers--Pro 5.0--3G alt--U/D pullies--A/C delete--190 LPH Walbro FP--Compucar N2O kit--FMS alum D/S--Taurus fan--Weld Draglites--Mallory 685 ign Box--dccontrol fan controller
13.0 - 108 mph - 1.9 60' - 90 shot N2O and 175k on the clock
Old June 2nd, 2007, 01:43 PM   #11
thomaspatton is on a distinguished road
I'm not sure about the '94, but I know the foxbodies had a bad problem with faulty heater cores. The one in my old 87 went bad and I had to run a bypass hose form the heater core inlet-to-outlet and it cooled fine. I'd check the other solutions listed first, though, cause like I said I don't know about the 94's.
Old June 2nd, 2007, 01:46 PM   #12
Heater core issues will not cause overheating.
-Mike
Link to My Site
Stroked and Blown!
Threads Similar to: OVER Heating Issues......
Over Heating Problem? Fox2102 V6 Mustangs 11 November 9th, 2007 10:25 PM
Does Heating Affect Hp like AC does? mustangmanic 99-04 2 November 9th, 2007 05:26 PM
over heating jersey98gt 96-98 40 September 20th, 2007 01:54 PM
still heating up..... lwhitetrash88l V6 Mustangs 20 June 22nd, 2007 03:13 AM
over heating? kreil45 5.0 Mustangs 8 May 24th, 2007 03:47 PM
