drive shafts
I have pulled the drive shaft to change some worn U-joints.. when i took out the bolts and release the shaft from the rear end there was alot of space left between the end of the drive shaft and the rear axel....(a good inch to 2 inches). the question is how much space should there be and what is the length of the drive shafts.... i think some ass has put the wrong one in my car.
btw it is an 86 5.0L 5speed. thanks for the help |
I'm confused? The 4 12 point bolts should hold the drive shaft firmly against the pinion. I'm not sure how there could be any space in between? The yoke on the transmission side slides in and out a few inches. remember also that if you jack the car up by the body, as the axle drops down it also gets closer to the transmission (it pivots about the control arms), so you want your yoke to be able to move in enough to accomadate suspension travel, otherwise you'd be in a serious bind...
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
the 4 bolts do hold the drive shaft to the rear end,,,, however when i pull the bolts off and push the drive shaft towards the transmission, there is a 2inch or more gap between the end of the driveshaft and the rear end... I think it is the wrong axel because i have never seen this much space on other mustangs before,,,,,plus the u-joints that i just picked up don't fit,,,soooo!
#4 | |
'88 LX body '91 GT D/T
8.7 in the 1/8th
Founder of the I don't like my shit centerd and want it back the way it was dammit! club www.myspace.com/evoalliance greatest band alive |
ok got the deal,,,, 86 mustangs have the same u-joins for auto and standard. 87-93 have two different size u-joints for auto and standard....still neither of the u-joints still fit.. after an hour of so f&%*^ around we found that the drive shaft is fron an f150 standard. i guess this is a common swap for people whom like to bend drive shafts.. And for the dick who sold me the car, thanks for mentioning ""NOTHING!"" was changed from tranny back.
Thanks everyone for the help in diagnosing this situation |
Hey, at least there is a bright side....Now you can order a light weight aluminum one!
What year F150's have the driveshaft that works?
not sure of the year, but it is supposed to be out of a standard 5 speed f150 with a 5 lt.. not extended cab or any other shit
Threads Similar to: drive shafts
| I used to drive an Evo | homebrewed | New Members Introductions | 4 | February 13th, 2007 04:22 PM |
| 7 tooth drive gear or 8 tooth drive gear for my 98 GT manual | Blue98GT | Modular Mustangs | 1 | January 6th, 2007 08:27 PM |
| i cant drive 55 | Invictus | Videos | 1 | December 22nd, 2006 01:24 PM |
| Is It Bad To Drive With... | 00SoSlow | General Tech | 2 | September 23rd, 2006 02:26 AM |
