t5 grinding in reverse
Old May 30th, 2007, 11:31 PM   #1
tayboo24's Avatar
91 Talon TSi
dunno?
tayboo24 will become famous soon enough
Send a message via MSN to tayboo24
hey im new to this moddedmustang site here really lovin it so far ... wondering what could be wrong with my car it is grinding real bad in reverse, and i have to back up real slow or it will pop out. jsut bought it with this problem, wondering if anyone out there has any ideas. thnx
Old May 31st, 2007, 01:25 AM   #2
neverfastenough1's Avatar
I am pretty sure a lot of them have the grinding reverse. It is not synchronized. Are all of your other gears fine? Is your clutch engaging before it gets close to the floor. Try shifting to third before you put it into reverse. See if that helps any. Welcome to the site.
Old May 31st, 2007, 02:06 AM   #3
homebrewed's Avatar
'88 LX body '91 GT D/T
8.7 in the 1/8th
homebrewed is on a distinguished road
Yeah, mine does that too. My neutral safety switch is disabled, so I go 5th to redo if I need to back up. Its not popping out of rewind like yours, but sometimes, on a downshift, 2nd won't fully engage. I have a brand new clutch in mine also. Thought that was the problem. It was grinding like that before, but that didn't fix it. Other than the occasional shearing, no problems outta the T-5
Founder of the I don't like my shit centerd and want it back the way it was dammit! club
www.myspace.com/evoalliance
greatest band alive
Originally Posted by Tony_90fox View Post
I wish there was a :lickmynuts smiley, because i would use it now
:lickmynuts
Old May 31st, 2007, 02:34 AM   #4
Mr_Evil's Avatar
Mr_Evil is on a distinguished road
Same here. I have to put it in another gear before putting it in reverse. And lightly feel reverse before I shove it in so it dont grind. Plus do the whole, disengage then reengage the clutch.
Old May 31st, 2007, 04:02 AM   #5
1989 GT Hatch
YNOT is on a distinguished road
my research found go into 4th before reverse.
Old May 31st, 2007, 03:32 PM   #6
tording92lxnotch is on a distinguished road
This is normal for a T5. It has no syncronizer for reverse so there is no way for the collar to syncronize to the gear speed before the teeth engage. This is what causes grinding. If you go to another forward gear first it helps that gear and collar to engage without the use of a syncronizer. I have never heard of one kick out of gear in reverse so that is possibly an issue but the grinding going into reverse is pretty common.
92 notch--Shorty headers--Pro 5.0--3G alt--U/D pullies--A/C delete--190 LPH Walbro FP--Compucar N2O kit--FMS alum D/S--Taurus fan--Weld Draglites--Mallory 685 ign Box--dccontrol fan controller
13.0 - 108 mph - 1.9 60' - 90 shot N2O and 175k on the clock
Old May 31st, 2007, 03:58 PM   #7
usmcsawgunner's Avatar
1993 Mustang GT
13.2 @98.54
usmcsawgunner is on a distinguished road
Send a message via Yahoo to usmcsawgunner
could it be the shifter forks mabe?
Old May 31st, 2007, 04:10 PM   #8
Could be I guess. I have heard that if you have a bad tranny mount it can cause the tranny to sag and put pressure on the input shaft. I have read that this pressure on the input shaft puts the tranny in a bind and can cause it to kick out of gear in certain gears. Don't know if this counts for reverse also but maybe take a look at your tranny mount.
Old May 31st, 2007, 06:09 PM   #9
Big timin' in a small town
Drick's Avatar
2004 FX4 F150, 86 GT
Ynot is right 4 then reverse thats the trick works in mine
FX4 Crew
Crew member #1
Don't take anything I say to heart, I don't try to come off as an asshole. It just happens
Old May 31st, 2007, 07:46 PM   #10
ryans88gt's Avatar
He said it was grinding in reverse, not when he was shifting into gear. If that is the case, you likely have a bad reverse gear or idler gear. This would also explain the popping. Bent shifting forks could also cause this problem.
If it only grinds going into gear, then I agree with the above posts
Old May 31st, 2007, 08:04 PM   #11
Drick's Avatar
Im Pretty sure he ment grinding when putting it into gear because that is what happens the most
FX4 Crew
Crew member #1
Old May 31st, 2007, 08:23 PM   #12
ryans88gt's Avatar
Ummm....OK...but that isn't what he wrote...he said it was popping out of gear while he was backing it up and that he had to back up really slowly...
Doesn't sound like that has anything to do with shifting to me...I don't usually shift repeatedly while I am backing up...maybe I'm doing it wrong.
Old May 31st, 2007, 08:33 PM   #13
Drick's Avatar
Yeah ok you caught me Ryan well I guess it could be the shift fork popping it out of gear
Heres a solution thats free hold it in reverse when your going backwards J/K LOL
FX4 Crew
Crew member #1
Old May 31st, 2007, 08:38 PM   #14
ryans88gt's Avatar
I had a friend that once tried to do a reverse wheelie in a VW GTI by side stepping the clutch at redline, while his friend sat in the back seat and held the shifter in place with his feet Needless to say, the car never backed up under its own power again
Old May 31st, 2007, 08:43 PM   #15
Drick's Avatar
I would have paid to see that. That would have been some funny shit
FX4 Crew
Crew member #1
Old June 1st, 2007, 02:54 AM   #16
homebrewed's Avatar
8.7 in the 1/8th
Me too .... I agree totally^^^^^^^^^^^^^^^
greatest band alive
:lickmynuts
Old June 1st, 2007, 08:25 AM   #17
That is not funny. That was foolish and immature. It could have gotten someone seriously injured on top of causing the damage to the vehicle that it did. Yeah, I guess I would have paid to see it too! Carnage is cool. Sorry, didn't see the part where he said it was popping out of gear. Could be a fork. Stop driving backwards.
Old June 1st, 2007, 06:14 PM   #18
He said its doing two things. it is popping out of gear and grinding in reverse. I don't know how a manual transmission can grind if its already in gear so I would assume he means it grinds while he is shifting into reverse. Two issues. The popping out could be the fork yes.
Old June 4th, 2007, 12:18 AM   #19
ryans88gt's Avatar
OH yeah a manual can grind while in gear...especially if the forks are bent.
Two gears trying to engage at the same time means a big grinding noise
Old June 4th, 2007, 12:20 AM   #20
Blown5.0's Avatar
Blown5.0 is on a distinguished road
Its no big thing man, I have a 9'' rear end with 373 spyder gears and a posi, I grind in reverse almost 60% of the time i put it in reservse.
89 Mustang lx 5.0
11.5 Compression
Edlebrock 150 dry kit
1.70 0-60ft 11.20 @124
Threads Similar to: t5 grinding in reverse
reverse is gone... i have a question or two burnout5.0 94-95 8 June 28th, 2007 08:12 PM
reverse knock JASonic V6 Mustangs 11 June 14th, 2007 09:50 PM
T45.... No reverse? This is embarassing Slowbra_12 96-98 7 June 4th, 2007 12:17 PM
Reverse...wtf? marcfiebka 99-04 8 April 20th, 2007 05:18 PM
reverse w/gt good stanged out V6 Mustangs 14 March 2nd, 2007 12:38 PM
