Stereo hums with engine! - Page 3
Old December 6th, 2011, 10:27 PM   #41
cleangtvert's Avatar
1991 gt vert
cleangtvert will become famous soon enough
dude ! scrap the 460 and problem solved! if you went through the grounds than its in the amp/amps.
Old December 7th, 2011, 12:26 PM   #42
fogged306's Avatar
89 GT
Ok then disconnect your radio completely, take a powerprobe and power up your remote wire in your radio harness. That should power on the amps as long as that's how you have it wired. Start up the car and see if you still get the noise with no deck but amps on and everything connected to them. If you still get the noise then the problem is with your amps, input wiring for the amps, or the amp power circuit. If you don't get the noise, verify the amps are on by quickly touching a 9v battery across one of the speaker leads when the amp is powered on. If you get a popping noise out of that speaker then the amp is on, and your problem is with a ground loop between the amps and deck, power circuit for the deck, or the deck itself. You basically need to narrow down the issue by process of elimination.
Threads Similar to: Stereo hums with engine!
99 GT stereo help! edwardgoalie1 99-04 5 September 27th, 2011 02:21 AM
Stereo making engine noises through speakers Stangalang04 Audio/Video 16 November 26th, 2009 10:02 AM
Need some help with stereo... 03GTguy Audio/Video 6 February 4th, 2009 05:43 PM
Look at this stereo vfast The Clubhouse 7 January 28th, 2008 06:07 PM
New Stereo Shorty's Stang Audio/Video 6 August 5th, 2007 12:50 AM
