Clunking Sounds?
Old November 29th, 2011, 12:10 AM   #1
1995 Mustang GT
mcglsr2 is on a distinguished road
Clunking Sounds?
So I just had some work done to my 95 GT: I got new Moser axles, 3.55 gears, Torsen T2, aluminum driveshaft, and new trans fluid. Initially, the car was great, no sounds. A couple days later, I am starting to hear a clunking sound, especially in low gears. If I put the car in say 1st, get going, let off the gas a little, and get back on the gas, I can sometimes make it clunk. It happens a lot when shifting. I don't hear it so much in the higher gears. What's going on here? Is this normal? Some searches I've done have said it's a backlash issue, other searches said some clunking is normal, etc. I am going to call the shop up, but I would like to at least know whether it's normal or not (in the event that they tell me it's normal when perhaps it isn't).
If it's normal, fine, I can live with it. It's just that the car never did that before, and now it's got new parts, and it's doing it. So that concerns me. For what it's worth, I've got MM rear lower control arms, which should add to NVH, however I had them on the car before the rear end work, no clunking. So I really don't think they are causing it.
Any thoughts or ideas?
Edit: I forgot to add, it sounds like it's coming from the trans tunnel, behind the shifter where the trans snout is. I don't know for sure if it's there, or if the sound is traveling up the drive shaft and that's just where I happen to hear it.
Old November 29th, 2011, 12:36 AM   #2
NOR*CAL's FINEST
3valveStallion's Avatar
2006 Mustang GT
Established in the back of a Boss 429 circa 1988
3valveStallion will become famous soon enough
my s197 does the same thing from time to time, especially double clutches. Its your drive shaft and UCA, it travels from the trans to the diff. that makes the clunk. Its just a noise, but keep an eye on it just in case, should be nothing
(BBK TB)(JLT CAI)(BMR A-Arms)(J&M LCAs)(Pypes C-back)(BAMA93)(PS LTs)(PS O/R H)(Steeda CMDPs)(Prothane Bullet Mnts)
Old November 29th, 2011, 10:39 AM   #3
1995 Mustang GT
I have the stock rear UCAs, though I did replace the bushings at the pumpkins. That was also done before the gear change, no clunking.
Old November 29th, 2011, 02:50 PM   #4
johnGT's Avatar
1995 Mustang GT vert
johnGT is an unknown quantity at this point
My dads 05' GT does the same thing if you let off the clutch a certain way. Does it do it all the time or just when you do sloppy take offs?
1995 Mustang GT vert: STOCK, AODE (B&M shift kit), 2.73 gears, red leather, 410,000~ miles.
2007 Mustang GT: 4.6, 5-speed, 3.55 gears, black on black. (dads car)
1975 Camaro LT: 305ci, TH-350, weiand intake, 600cfm carb, 3.42 gears.
Old November 29th, 2011, 02:59 PM   #5
black02's Avatar
02 Mustang GT convt
27.12 @55
black02 is on a distinguished road
Mine did the same thing my drive shaft bolts backed out the tiniest bit
Sent from my Autoguide iPhone app
Old November 29th, 2011, 06:00 PM   #6
91cobra5.0's Avatar
98 Cobra
check the lug nuts on the back rims, check drive shaft bolts, was the drive shaft new? or used? sounds like a u-joint?
Old November 29th, 2011, 10:26 PM   #7
ryanw's Avatar
1991 Ford Mustang GT
check U-joints
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old November 29th, 2011, 11:49 PM   #8
1995 Mustang GT
Not sure if it's sloppy take offs, just what I consider normal driving. If I baby it, as in I'm trying to gently mesh gears together, I don't hear it so much. However, if I just drive normal, I can hear it. If I were to imagine what the sound is, it's almost as if the drive shaft is being pushed back and forth as the drive gears are engaged (not saying that's what it is, but the sound I imagine that making is what I am hearing).
Well I hope it's as simple as that
Originally Posted by ryanw View Post
check U-joints
I've already called the shop and I'm taking the car back in Thursday to have them look at it. Brand new Al. drive shaft, brand new U-joints (came with the drive shaft), brand new 3.55, brand new axles, brand new Torsen diff. It's all new, including the clunking sound - as in I didn't hear it before. At first I was thinking maybe it was the transmission as I know that has some wear on it. However, it didn't make the sound before, and I did just have the rear end worked on, so I'm thinking it's probably something to do what the new stuff just done. And it started gradually. When I drove off from the shop, it was all good. Several days later (and a good amount of driving), I start hearing this noise.
Old November 30th, 2011, 03:25 PM   #9
91cobra5.0's Avatar
98 Cobra
they could have shimmed the carrier wrong when they did the gear install. they could have shimmed it right on the borderline of the tollerance and once it wore in the tollerance would have increased
Old December 1st, 2011, 12:04 PM   #10
PONYMAN's Avatar
PONYMAN is on a distinguished road
Send a message via Yahoo to PONYMAN
keep us posted .
Have you driven a Ford lately ?
Old December 1st, 2011, 03:46 PM   #11
1995 Mustang GT
Huhokay. So the guy that would be looking at my car today went home, so I'm scheduled to take it in Monday. So I got nothing until Monday.
Old January 10th, 2012, 09:20 AM   #12
1995 Mustang GT
Sorry for the late update. The people at the shop said it was normal, they checked everything and it was all good. So perhaps the transmission is getting a little sloppy or something, or perhaps it's just normal. But they did say it wasn't a problem. Since then, I've ran the car at road course at HMS, and the car worked fine, no issues. So I'm going with it's normal sounds.
Threads Similar to: Clunking Sounds?
clunking noise 1998 mustang power 96-98 4 February 16th, 2011 02:08 PM
Clunking or popping BA98GT 96-98 13 January 10th, 2011 11:46 PM
bad clunking from the back StutteringStang06 2005 - 2010 9 July 11th, 2010 10:09 AM
clunking in front end Gilmourisgod75 99-04 6 July 2nd, 2010 07:05 AM
clunking sounds from rear when turning left?? a1yola 5.0 Mustangs 3 April 10th, 2009 09:53 AM
