Discussing My 93 gt is running hot a little help in the 5.0 Mustangs Forum. Well first off i jsut bought this car it is a 1993 5.0 gt ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
My 93 gt is running hot a little helpi took it out for a little drive to day and it was running good until the temp gague just started rising to about the 250 mark so i stopped and let it cool down and turned on the heat to get back home. and the whole way it was running around 200 210 degrese. could u guys help and give me some ideas what it could be? i have an after market eletric fan on it. and thats all i think it has for the cooling system. |
1990 Mustang LX
9.36@143 mph
Check the coolant level. Is the car all stock or is it modified? Is the fan turning on? If you can't find anything obvious, the next step is to go have the cooling system pressure tested.
Racing in memory of Dave Bandt 11/19/69 - 3/23/08 "he's traded his wheels for wings" Professor of Natural Aspiration ![]() Thanks to: Artie at Trick Flow, Dave at Team Z Motorsports, Brian at Total Engine Airflow and Harold at Furo Racecraft |
Maintenance Man
11.47@120.58
Check the radiator cap too, something as simple as that can cause it to run hot.
Is with all "new" 13 year old cars you should do a FULL tune up and that includes flushing the cooling system. Than see if the problem is still there.
You say 250* how? Is there a REAL gauge in the car, not the stock one. Is it right? 250* is at a boiling point, did you gear it boil? Did it run different or were you just going off the gauge? Is there a thermostat in there? What temp is it? 180* is uasually the best for a 5.0. What cooling fan is on there? If its a "black magic" or some off brand Pep-Boys one, you prob found your problem. I
-Mike Link to My Site Want to Play Some Pool??? http://img29.photobucket.com/albums/...utsigtest2.jpg Soon to be stroked and blown! |
1999 Ford Mustang V6
did you install the fan, is it pointing the right way?
...even fire and single cammin |
Don't mean to change the sub, but what's the normal temp the car should run anyways? is it 210? mine goes to 210* and stays there.
THE BEAST IS FOR SALE!!! GTX RACING & PERFORMACE CLUB OF TEXAS Meets and greets, drag racing and good eats, you know you want it. GTX Racing Tony P. 214-257-3635 http://www.moddedmustangs.com/forums...vehicle&CID=43 |
flush your system and put a 180 degree thermostat in there.....
#8 | |
also, I think clutch fans suck, my police one broke, and never cooled worth a crap, I have the black magic, and it runs cool, even with pullies at an idle, draws alot of amps, so an alternator upgrade is recomended, but i have the stock alt. later, and cool site.
1990 SSP coupe t-5: Explorer heads and Intake, E cam, 24lb injtrs, unequal shorts, x-pipe, subframe connectors, 65mm tb, 3.90 grs. Best e.t. 12.70 @ 107.65, 26x8.5 m/t drags, 1.71 60' |
#9 | ||
First of all, My fan moves 2800 cfm, I bought this fan before people were really using crown vic, and whatever you have, fans.
I have friends using 03 cobra fans on fox stangs, and all kinds of other fan's, ford tauraus etc... do you see my point? All i did was get a fan when i needed one, and it works, a 1400 cfm fan would not be enough, so i agree with that.
ok
thanks for all he help i changed out the thermastat the one in there was shit. i put in a 192* thermastat and it runs no hotter than 210* and my fan kicks on at 190* is 210 still to hot? |
#12 | |
1990 Mustang LX
9.36@143 mph
I run a Flex-a-lite Black Magic fan and it cools my 718 horsepower engine just fine whether I'm racing, street driving or idling. I've used Black Magic fans on every single Mustang I've ever owned. They bolt right on, fit great, look great and work great. Who ever told you they are junk has never used one.
210 is normal operating temp, if u run too cold then u wouldnt produce as much power, 210 is peak performance temp.
make sure u have an adaquate amount of anit-freeze mixed with the water and the radiator cap is good, if all is well your coolant boiling point will be around 265 degrees...
#14 | ||
![]() Glad to see you like the flexalite, I have known other people that dog them too, on other stang sites. but fact is, I live in south tx, my car has ac, and pullies, idling in traffic isnt a problem, but the temp guage climbs slowly, probaly to around halfway, nothing major, never boil's over (knock on wood) I happen to have a pep boys radiator :wink My friend with the 03 cobra fan says he's tossing that one for one like mine, he says "it blows/sounds better, and smaller.
#15 | |
1990 Mustang LX
9.36@143 mph
Well I just call them like I see them and I have seen black magic fan issues. Glad its works for you.
thanks for all the help
well shit this town aint big enuf for the both of us |
Threads Similar to: My 93 gt is running hot a little help
| RUNNING HOT!!!!!!! | BLACKNIGHT5.0 | 94-95 | 37 | September 5th, 2007 03:27 PM |
| Got Her Running, But wont stay running...help? | Speedstang302 | 5.0 Mustangs | 9 | August 21st, 2007 12:44 AM |
| not running right | jkovacs60 | General Tech | 2 | August 3rd, 2007 02:13 AM |
| Bad running... | alabamastanger | 5.0 Mustangs | 4 | July 15th, 2007 06:25 PM |
| Just Got Done Running a 89 LX 5.0 | Bigb2000GT | 99-04 | 1 | March 19th, 2007 06:57 PM |
