New to the game.
Hey guys,
I'm fairly car smart..I'm reading and learning more about the 5.0's everyday. So I hope I don't irritate anyone with annoying/old questions. But anyways..my 89 is down right now for a rebuild due to piston rings going bad. I want to get around 300 wheel horsepower. I've read alot about the ford alphabet series cams, I've heard alot of negative reviews on them mostly because of being outdated, but I wanted to know a pretty good heads/cam combo? Are the GT40xAluminum heads any good? I've seen a set new for 600$, which isn't bad at all from what I've seen for prices on aluminum heads. If I were to get these heads what kind of cam should I run? I still want plenty of low end power as well as high end, up to let's say 5,000? Roughly..give or take some maybe. Are the GT40 intakes of a Explorer really worth the money? Off a cam, gt40x heads, and gt40 upper and lower intake what kind of gains should I expect? What size of Throttle body can the gt40 intake handle? As I heard the stock intake is up to 65mm? I just wanted to get these answers clear, as I've read and read, and heard so many mixed opinions it makes it hard to comprehend what's good or bad. But I'd really appreciate the feedback. Thanks - Tanner |
1989 Black LX---Turbo
The GT40X heads are not a terrible head, they flow fairly decent numbers for a mild street build. If you can get a new complete set for $600, that's a steel. I've used several of the letter cams over the years, and they work OK. My last 5.0 build I had a stock 89 short block with E303, Twisted Wedge 170's, carb, etc. It ran good, but I then swapped out the E303 for a Comp XE266HR, and WOW what a difference! Way more power, way more driveabuility, light years ahead of the E cam. I would highly recommond it in a 302. As far as the Explorer intake, I've used it with very good results, but it's gona need some port matching. The lower has very small ports. A few years back I ran 11.69@114 with a stock 5.0 short block, Trick Flow Stage 1 cam, Twisted Wedge 170's and a ported Explorer intake. You can easily port the opening for a 70mm throttle body.
89 LX Black, Boss 331, C4,T76BB, FAST EFI 82 Capri RS,89 5.0 HO,Comp XE266,TW 170,T5,etc. 73 Dart Sport 340, 410ci Bracket Brawler 72 Demon 340 4-speed 1 of 1667 01 Ram Quad Cab 03 Grizzley 660 |
#3 | |
1995 Mustang GT vert
Yeah the alphabet cams are the cavemen of cams. Pro comp and Steeda cams are some of the best ones out there.
The gt40x heads can easily get you to 300hp. You are going to need a decent cam to get there though. As for throttle body sizes and what not, 70-75mm should work just fine. Gt40 intake is also a good upgrade and will keep the powerband from dropping off early.
1995 Mustang GT vert: STOCK, AODE (B&M shift kit), 2.73 gears, red leather, 410,000~ miles. 2007 Mustang GT: 4.6, 5-speed, 3.55 gears, black on black. (dads car) 1975 Camaro LT: 305ci, TH-350, weiand intake, 600cfm carb, 3.42 gears. |
91 Mustang GT
1991 sliver GT
gt40 heads and cobra upper and lower intake with 70mm throttle body and a vortech v1 on a 302 short block with notched pistons and a custom ground cam gave me around 330. This was on 93 octane and a very good gas milage plus my Ac works. ALl that cost me around $5,000. Im pretty sure its was below what i can actually put out, but i was happy and left it at that.
Im in the same boat as you hahaha
Threads Similar to: New to the game.
| new game on mw2? | 08blkgt500 | The Clubhouse | 12 | December 23rd, 2009 02:26 AM |
| ***Flash Game** My Brute - Fighting Game | Outlaw GT | The Clubhouse | 14 | May 13th, 2009 02:45 PM |
| ***Flash Game** My Brute - Fighting Game | Outlaw GT | Forum Games | 0 | May 10th, 2009 02:32 PM |
| Good Game Microsoft. Good Game. | Ace417 | The Clubhouse | 5 | December 31st, 2008 05:12 PM |
| Game day!! | Onemanzu | The Clubhouse | 1 | September 15th, 2007 10:41 AM |
