89 fox AOD gear options
Old December 2nd, 2011, 02:42 PM   #1
mtw002's Avatar
2003 vert gt
12.703@ 107.65 KCIR
mtw002 is on a distinguished road
Send a message via AIM to mtw002 Send a message via MSN to mtw002 Send a message via Yahoo to mtw002
Ok i'm building a 89 4cyl fox w/302. I've already pulled the motor and have a 92 5.0 mustang motor ready to swap in w/gt40p heads w/aftermarket valve springs. The rest of the motor is stock. Since the 4cyl car was a auto i'm going to be using a AOD w/a 2500stall. My next question is as follows, I have a 8.8 rear end w/mini spool and 4:56 gears. The car is going to be running a 28in tall tire out back. I know a lot of people say dont fear the gear but also alot of people say it wont rev very high with stock parts. (true) The car will be used in town (never long trips on hwy) and ran at the 1/4 mile. My fear is that the AOD will be trying to go into OD by the end of the track. Could i get away with them or will it not work at the track?
I also have a 96 gt rear end w/stock gears if all else fails.
Cars Dont Power The Front Wheels, They Lift Them
4v teksid block w/2v heads FINISHED 14 April 2010
2003 vert gt 2v teskid build 12.7 @ 107 (SOLD)
1989 mustang lx
Old December 2nd, 2011, 03:06 PM   #2
PhillyGT's Avatar
2001 Mustang GT
13.8@101.58mph!
PhillyGT is on a distinguished road
Keep it in D and it wont go into o/d.Also 4.10's FTW
Dropped on Eibachs,K&N FIPK,Mac-prochamber o/r,Flowmasters.Short throw,Heavy Right Foot Mod
Old December 6th, 2011, 06:06 PM   #3
mtw002's Avatar
2003 vert gt
12.703@ 107.65 KCIR
I'm just going to run it and see what it does. The motor might be out of breath by the end of the track 6200rpm or so. If it gets too high i guess i'll just let it go into OD and not give it WOT. Then change the gears for 410's or 355's. I do want to end up turbo'd sometime.
1989 mustang lx
Threads Similar to: 89 fox AOD gear options
Gear options Cope 2011+ 9 February 17th, 2011 09:24 PM
Rear Gear Swap Pricing and Gear Oil TStang 2005 - 2010 9 August 17th, 2010 06:09 PM
Cam gear and camshaft position sensor gear... 99v6stang V6 Mustangs 17 January 17th, 2008 02:00 PM
4.30 Gear to much gear for street use/daily driver? Bigb2000GT 99-04 10 March 28th, 2007 05:22 PM
