1988 mustang LX coupe
Kenne Bell guys... 351w
I'm looking to drop my 1.5L kenne bell onto a 95 351w motor but need to figure out which intake this thing might fit.
Here's a list of what I got: Kenne Bell 1.5L Blower, - Holley Systemax I Lower - Polished discharge side and piping - Upgraded to Flowzilla intake side - Includes the original polished intake side good to 75mm TB - Custom TIG welded A2A piping - Front mount IC - Bypass valve with Magnusson valve, the one KB uses on Flowzilla kits - All snout brackets and PS pump relocation brackets needed, included - Needs bracket alteration to work on AC cars (PS and AC pump locations are the issue) - 2 - 6 Rib pulleys ( includes pulley puller - hard to find ) for 6 and 9 psi - Full 8 Rib conversion setup, custom crank and blower pulley made by ASP - 12 psi - 8 rib Alt, PS, and Cobra Water pump pulley. Includes Gator 8 rib belt. Now obviously I cant use my holley lower but if it fits that is it possible it'll fit the 351w lower from an F150?
89GTcoupe- 304ci, tfs1cam, tftw heads, 2.5"flowies, GT40intake, TF23lb inj, t5 w CFDF, SN5bolt, 3.73gears, GTkit, Y2K R wing, 17" Tribars 88coupe- lookin for a new powerplant |
Threads Similar to: Kenne Bell guys... 351w
| 96-98 Cobra Kenne Bell Guys | brharris777 | 4V / SVT | 19 | July 22nd, 2010 01:16 PM |
| ? About a Kenne Bell 2.1 | stangersvt97 | 96-98 | 12 | June 12th, 2010 11:11 AM |
| See what you guys think my 97 Cobra with Kenne bell | stangersvt97 | 96-98 | 20 | May 28th, 2010 02:00 PM |
| Kenne Bell | 02blkpny | 99-04 | 23 | February 14th, 2009 07:37 PM |
