clutch makes noise after replacing the clutch cable
Old December 5th, 2011, 07:31 PM   #1
89 GT
BlkStallion89 is on a distinguished road
I need help, idk wats going. So I replaced my clutch cable earlier today, and when I went to start the pony the clutch was making screeching/grinding noise. So I'm wondering wat I did wrong? Oh and I do have an adjustable clutch cable. I tried tighting and loosening it but same noice occurs.
Really need help. Oh and my gears wont go in either.
Old December 5th, 2011, 10:01 PM   #2
gripthenboost's Avatar
91 Mustang GT
1991 sliver GT
gripthenboost will become famous soon enough
u did it yourself?
Old December 5th, 2011, 10:41 PM   #3
89 GT
Yea me and my buddy
Old December 5th, 2011, 10:50 PM   #4
ryanw's Avatar
1991 Ford Mustang GT
are you sure you bought the right cable ? what problems were you haveing that made you decide to replace it ?
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old December 5th, 2011, 11:28 PM   #5
89 GT
Well I didn't replace it, I had to remove it cause it was put in between the aftermarkert headers from previous owner. I went to put the stck headers so I had to remove the cable, but when I put.it back on and turned the car on the.clutch started screeching and it wont go into gear. But it only screeches when the peddle is pushed in
Old December 5th, 2011, 11:42 PM   #6
\/ Hidden Bewbs \/
sikedsyko's Avatar
01 Cobra Vert
sikedsyko is a splendid one to beholdsikedsyko is a splendid one to beholdsikedsyko is a splendid one to beholdsikedsyko is a splendid one to beholdsikedsyko is a splendid one to beholdsikedsyko is a splendid one to beholdsikedsyko is a splendid one to behold
I don't know if its the same with those cars, but in mine I had a similar issue and had to install a firewall adjuster to fix the problem.
MM Cobra Club #66
Old December 5th, 2011, 11:46 PM   #7
bigjohnstud4200's Avatar
2000 GT 'vert
bigjohnstud4200 has a spectacular aura aboutbigjohnstud4200 has a spectacular aura aboutbigjohnstud4200 has a spectacular aura about
did you have trouble getting the cable on the clutch fork? maybe you knocked the clutch fork off the pivot point. get under there and tap on the end of the clutch fork pushing towards the TOB, ie. up on the fork.
"...but don't say my car's topless, say the titties is out"
Nas
Originally Posted by thrashersonmomma09 View Post
( member as in person not as in cock although i do love cock)
Old December 6th, 2011, 12:11 AM   #8
89 GT
No I didn't have trouble cause I have the firewall adjuster. I checked the fork but its still stiff so I don't think it fell outta place.. idk wat could be causing it to screech, and the gears go un fine when the engine is off.
Old December 6th, 2011, 04:58 PM   #9
Stdyhand is on a distinguished road
If you can't get it into gear I would be looking to see if the cable is still too loose. The fact it is making screetching noises when you started it also leads me to believe the clutch is not disengaged. I would have your buddy push the clutch pedal to the floor while you measure the travel distance of the clutch fork.
Old December 6th, 2011, 10:04 PM   #10
95ish5.0
SSteady98's Avatar
1995 GT
Slow
SSteady98 is on a distinguished road
Send a message via MSN to SSteady98
I'm wondering if I need to get a cable adjuster based on what I've been reading here.... It is hard to go into gear unless i push the pedal all the way down and it glides easy. same for reverse, excecpt if the pedal isnt all the way down it dont go into reverse...Am I right? Also hear the griding of the plate unless i push it all the way down... Guess the Spec stage 3 needs that kind of attention.
1995 Mustang GT
BBK Shorty Headers, H Pipe, CAI, UDP, 255lph Fuel Pump
Spec Stage 3 Clutch
FR500's all the way around
Cobra R Hood
*Want*
Gears, Cam, TW Heads, Turbo(Last)
Threads Similar to: clutch makes noise after replacing the clutch cable
New clutch cable and quadrant still short on clutch sharpshooter33 99-04 1 November 4th, 2011 09:28 AM
replacing clutch cable, how hard is this?? 94pacecarSVT 96-98 2 December 5th, 2009 11:13 AM
Clutch Or Clutch Cable OR Shifter??? 96GtGoodz 96-98 21 July 27th, 2009 02:59 AM
CLUTCH AND CLUTCH CABLE MAJOR PROBLEMS Hububula 5.0 Mustangs 3 May 28th, 2007 10:08 AM
Getting My Clutch Quadrant, Adjustable Clutch Cable and 97Cobra 4V / SVT 3 May 2nd, 2007 02:33 PM
