Rear control arm bushings
Does anyone know a way to tell when rear control arm bushings are going bad?
what material are they?
If you have stock control arms, look for the usual stuff. Dry rotting, splitting, gap forming between the rubber and link. Try to twist it by hand. If you can twist it by hand, they are worn. Might have to jack it up for that one. I check them every time I have the rear wheels off. Also if you hear a clunking sound in the rear when breaking or pulling off, thats a good sign they are shot.
#4 | |
1990 LX hatch
I dont have stock arms or bushings but ever since my last run at the track I hear 1 clunck and a bit of swaying in the rear when I lay into it.
1990 LX hatch
Prolly a bad bushing, my buddy has adj. lowers with the front bushing being a hiem joint the rear a poly one. after about 20 passes the sleeve had worked its wat through the bushing to the back. I have never seen that before.
Yep, probably worn. The clunk is the control arms binding up. Also check your mount points for damage.
yeah I am gonna this weekend.. thanx guys..
Threads Similar to: Rear control arm bushings
| lower control arm bushings | noppe180 | 96-98 | 5 | November 7th, 2007 07:09 PM |
| control arms or just bushings? | crappy_head | 99-04 | 2 | September 15th, 2007 06:51 PM |
| Control Arm Bushings? | CMcD 5.0Lx93 | 5.0 Mustangs | 5 | August 8th, 2007 01:37 AM |
| control arm bushings | angermgt | 5.0 Mustangs | 5 | May 15th, 2007 08:30 PM |
| Lower Control Arm Bushings | cali 5.0 | 5.0 Mustangs | 3 | November 13th, 2006 07:04 AM |
