Compression stops? Are they needed?
Old December 7th, 2011, 02:14 PM   #1
1991 Ford Mustang GT
Stdyhand is on a distinguished road
I went to get a set of valve cover gaskets today. I was expecting simple gaskets made of either cork or rubber but the parts dealer said the gaskets I was asking for did not have "compression stops" with them.
What are compression stops? Are they really needed?
Right now the car has stock heads. I am not sure if the valve covers are stock or not. They say "Ford Racing" on them but I wasn't sure if the stock valve covers had that on them.
Are these stops meant only to keep you from over torqueing the gasket? I was reading online and a couple people said they cracked their valve covers using compression stops.
I mainly want to know if I can go without using them? I know how to torque a valve cover down without over tightening it.
Old December 7th, 2011, 04:26 PM   #2
fogged306's Avatar
89 GT
Yea you can use a gasket without them. I've done it quite a few times in the past. What you said is right, they're just there to stop you from over tightening.
Threads Similar to: Compression stops? Are they needed?
with or without shift stops? 01MGGT 99-04 11 February 3rd, 2011 11:58 AM
It never stops.. BlackSunshine The Clubhouse 24 August 24th, 2010 08:53 AM
Piston stops... OH03GT 99-04 2 April 17th, 2010 07:06 PM
MGW shift stops NMR-2vGT 96-98 4 October 24th, 2007 10:05 PM
Stops like a new one Red87DropTop 5.0 Mustangs 8 September 30th, 2007 08:35 PM
