347 ignition timing NEED help
Old June 1st, 2007, 01:08 PM   #1
flamestang's Avatar
flamestang is on a distinguished road
I have a probe 347 with xfi comp cam I have pro product damper I sure the marks are wrong so I made a new mark for TDC. set base @15 btdc and engine does not perform. So I set distributer to where it does perform good (real good)but the timing is at about 15-20 ATDC. Has any one delt with this and is it OK?
Old June 1st, 2007, 01:53 PM   #2
86GT50's Avatar
86GT50 is on a distinguished road
Contact Bob Kurgan at KurganMotorSports.com he tuned my car & he'll know the answer immediately.
Old June 1st, 2007, 03:59 PM   #3
all motor
SALIV8's Avatar
92 coupe
9.94@136.40
SALIV8 is on a distinguished road
Re: 347 ignition timing NEED help
you're talking 15 degrees advanced i think, that's fine.
Old June 4th, 2007, 01:13 PM   #4
flamestang's Avatar
Thanks guys I got it figured out. Just had to find the real tdc mark :wink
Old June 4th, 2007, 06:56 PM   #5
89LX347's Avatar
89LX347 will become famous soon enough
what did you put your timing at?do you think you can out all 347s at 15 degrees advance? i put mine at 10 but do you think i could bump it up a little without detination?
I believe in art when it is not seen.
I believe in music when it is not audible.
I believe in God when He is silent.
Threads Similar to: 347 ignition timing NEED help
I Have Poor Ignition Timing OcOnnor220 99-04 3 November 3rd, 2007 02:41 PM
347 ignition timing flamestang 5.0 Mustangs 3 June 23rd, 2007 03:28 PM
A/F and spark/Ignition timing help Juggalo_X V6 Mustangs 9 April 30th, 2007 10:25 AM
MSD Ignition? cdunc24 5.0 Mustangs 2 September 13th, 2006 10:21 PM
Ignition! FaStStAnG5-0 General Tech 0 September 11th, 2006 01:14 PM
