Installing longer wheel studs?
Old December 12th, 2011, 07:54 AM   #1
1992 Mustang Lx 5.0 347ci
11.8@115
SloMo is on a distinguished road
Who here has installed longer wheel studs on their fox? I have drag lites and it seems I'm 2 for 2. Everytime I put on/take off Weld drag lites, I ruin a lug nut or stud. What's the reasoning for this? I'm not cross threading or anything wrong like that, but ALWAYS damaging something. Who here has done longer studs on the front and rears with Drag Lites with open ended lugs. I believe that will relieve the problem. Not sure about the longer studs for the front rotor, I thought they were a complete assembly. Are they changeable? Rears I'm sure are nothing more that pulling the drum cover, and sliding the axle out which should be removing the diff cover and c-clips, and out they should go?
Slow Motion... Quick reving, High compression, Big Boy 347 stroker... STROKER MOTION...
Old December 18th, 2011, 06:42 PM   #2
11.8@115
Nobody here has changed the rear studs with 3in studs?
Old December 18th, 2011, 09:23 PM   #3
86_Notch's Avatar
1986 lx notch
9.98 @ 135
86_Notch will become famous soon enough
When I finally upgraded to 31 spline axles I had a local chassis guy drill and tap the axles for 5/8 studs. It makes swapping rims super easy as you don't have to hold the rim on and fumble with trying to start a lug nut, you just slide the rim on and put on a spacer and nut.
" Spending money I don't have.... on things I don't need .... to impress people I don't know "
Old December 19th, 2011, 01:32 AM   #4
11.8@115
Sounds good, but I'm not going that built. I just wanted to install these 3in studs with some better shank lug nuts to keep from ruining the studs or lugs. I looked at my old repair manual that I forgot I had. It told me everything I needed to know. Going to be installing them Tuesday if time permits.
Old December 19th, 2011, 09:19 AM   #5
faststang90's Avatar
1994 splash
faststang90 is on a distinguished road
i did longer studs on my ranger that is for drag racing. i did it on the front and they did not have the right size so i had to drill the roto out to the right size. the rear they had the right size. pull the brakes off. then the rear i had to remove the cover, back the small bolt out that holds the pin in, remove the pin, push the axles in and pull the c clip. then the axle will come out. on the rear end i would install the posi stuff in the rear end oil.
Old December 19th, 2011, 03:09 PM   #6
11.8@115
Thank you, I appreciate it.
Old December 19th, 2011, 10:26 PM   #7
101fng's Avatar
2009 Mustang GT
101fng has much to be proud of101fng has much to be proud of101fng has much to be proud of101fng has much to be proud of101fng has much to be proud of101fng has much to be proud of101fng has much to be proud of101fng has much to be proud of
are you using an impact to put on and remove the lug nuts, because that will fuck up your studs in a hurry
Old December 20th, 2011, 08:36 PM   #8
wick22 is on a distinguished road
if you are taking the wheels on and off alot its a good idea to use anti-seize compound on them
Old December 22nd, 2011, 05:20 PM   #9
11.8@115
No, wasn't using a impact wrench on the wheels. Apparently I was over tightening them though. I looked on Welds website and they say to torque at 90 ft lbs, I was giving more than that by hand. WICK22...the site also said not to use anything like anti-seize.
Old December 22nd, 2011, 05:30 PM   #10
1994 splash
yeah 90 is what i take mine to. i think it is the lugs that i got are cheap. when i got them they had a big box thing they was in. i got some weld ones to install next but my old motor did not make it so i been dealing with it.
Old December 25th, 2011, 01:31 PM   #11
11.8@115
Got the studs installed, I didn't have a press handy. So I got real familiar with my bfh. Tearing the rear end open and getting the axles out was easy as can be. Beating the new studs in...not so much. I highly recommend anyone else doing this, use a press. Would have made it so much better.
Threads Similar to: Installing longer wheel studs?
wheel studs 04gtvert 99-04 6 May 28th, 2011 12:19 PM
longer wheel stud (moroso)...install mrbigjeep 99-04 11 August 2nd, 2010 09:47 PM
Installing longer rear wheel studs tbirdscwd 99-04 13 July 9th, 2010 12:12 AM
Installing head studs & Upper/lower intake sniperd 5.0 Mustangs 16 September 9th, 2009 06:04 PM
Wheel Studs 2000v6 V6 Mustangs 1 September 12th, 2006 08:38 PM
