stalls after warm up
Old June 10th, 2006, 11:51 AM   #1
dcraig8 is on a distinguished road
ok guys.... i have a 1994 5.0. mods: 3:73 gears,bbk cold air intake,under drive pulleys,76mm maf,70mm throttle body,mac equal length shorties,off road h-pipe,flowmaster 1712 american thunder catback exhaust,smog pump delete,msd 6a ignition with msd blaster coil,pro 5.0 short throw shifter,ford racing 1/2" intake spacer. here is my problem: it runs great first thing in the morning, no matter if i go 5 miles or 25 miles to wherever. iget back home, get ready for work and when i fire her back up it stalls at every stop i come to. i've replace about 12 worn out brittle vaccuum hoses and lines, cleaned out my i.a.c., throttle body, sprayed carb cleaner around everything(no loping) checked the torque on my manifold bolts, made sure the egr was operating correctly(dont think its seating all the way)put vaccuum gauge on the manifold and im only pulling around 15 inches. it should be around 20. anyone got any ideas????
Old June 10th, 2006, 06:54 PM   #2
IcantDo55 is on a distinguished road
Pull codes?
REPLACE IAC with NEW FORD one.
-Mike
Link to My Site
Want to Play Some Pool???
Stroked and Blown!
Old June 11th, 2006, 01:23 PM   #3
ttop5.0's Avatar
ttop5.0 is on a distinguished road
does it idle rough while it does run, once you start it back up???any lagging on the throttle?
Old June 11th, 2006, 02:00 PM   #4
it still idles a bit rough, like i have a racing cam in it, but it holds around 700-900 rpms
Old June 11th, 2006, 02:01 PM   #5
and there is no lagging in the throttle
Old June 13th, 2006, 11:23 AM   #6
cobralini is on a distinguished road
I beleive I am having the same problem with my 87 GT. It runs fine but sometimes the idle goes up and down and may cut off. When I come to a complete stop sometimes it cuts off.
I know there are alot of old parts on my car so I will start by replacing my IAC and all other vac hoses and sensors.
When I bought my car it had frogs, lizzards, spiders and wasps in it to let you know how long it sat but it did fire right up and sounded SWEEEEET!
I am sure the pior owner would not recognize it now.
Old June 13th, 2006, 12:39 PM   #7
im picking up a new I.A.C. tomorrow and taking it to a performance shop thursday to pull codes,i will let you know what happens in both cases
Old June 17th, 2006, 02:03 AM   #8
update: i replaced my i.a.c., did an egr delete mod, and reflashed the e.c.u.. the car runs great. no more stallin, and i picked up a little more power.
Old June 18th, 2006, 07:25 PM   #9
-Mike
Link to My Site
Stroked and Blown!
Threads Similar to: stalls after warm up
Car almost stalls ryanhewett466 5.0 Mustangs 7 November 8th, 2007 08:12 PM
car stalls when hot tims3.8stang V6 Mustangs 5 September 16th, 2007 11:45 PM
Warm A/C?!?!? Breakout V6 Mustangs 4 July 14th, 2007 12:21 PM
Stalls Out thagreen1 94-95 12 November 6th, 2006 11:26 PM
Car Stalls stangliter04 General Tech 7 July 17th, 2006 10:02 PM
