1988 LX Vortech
Finally ready for it's "closeup"
Take a look, feel free to comment |
1991 Ford Mustang GT
your neighbors must love you..lol
it sounds good
POWA! 24/7 fukkers
1 @ 1
does sound good, very clean!
Awesome vid. She sounds great dude.
![]() Sig by Tricep |
2006 GT
11.99@114
Very clean Hatch. Dumps sound great. Did you get it tuned yet? Why is your tensioner upside down?
![]() 2006 GT (Fastest) 2004 COBRA (Faster) 1990 LX 5.0 (Fast) |
91 Mustang GT
1991 sliver GT
At this time of the year all my neighbors get a cheap $5.00 bottle of wine. That buys there silence for another year.
lol
#8 | |
The tensioner is uside down due to clearence issues, this setup worked and it didn't cause problems anywhere else. Also, some of my neighbors are car guys, not all of them (I do get the stink eye from a select few) I have to admit, working on a supercharged car had a learning curve. |
2006 GT
11.99@114
Looks like you have stock valve covers. I’m guessing they aren’t stock heads though with those HP numbers. Sounds like a mild cam, tough to tell with the dumps. What pulley are you using @ what PSI? You need to get some of those hood lifts for Christmas.
1991 Mustang GT
Looks good and sounds good, whats all done to it besides the obvious, Stock bottom, heads, cam? Very curious on how you hit those numbers...
#11 | |
Vortech Supercharger - V2 with discharge tube and fuel management system (9lb pulley) Edelbrock RPM aluminum heads with 1.6 roller rockers (heads have been ported & polished) Cobra Intake - upper & lower ported Motorsport X303 Camshaft 65MM Throttle Body 75MM Mass Air 36lb Injectors with fuel pressure regulator 255L Fuel Pump MSD 6AL Ignition with boost retard control in car Griffin Aluminum 4 Core Rad 1 5/8" Mac Full length Headers Center Force Clutch (just installed) T5 Tranny with X parts and 2.95 ratio 1st gear 8.8 Rear End with precision 3.73 gears 31 Spline Axles Machine Bars (Traction Bars) 90/10 Struts, 50/50 Shocks Cobra R 17x9 Wheels with Drag Radials on rear Autometer Gauges (Boost, Water and Oil) and shift light |
I have similar with stock bottom with GT40X heads and a V1 and get about 470RWHP. I have all the emissions attached and working (and it passes test easily), shorties, mechanical fan. I have a lift bar setup as well and I'm not a fan.
Can fill 7 car garage
Damn I miss my old 5.0
I can't watch this stuff, it makes me want to cry. BADASS car man. |
1991 Mustang GT
Wow, thats very nice...My setup is going to be a stock bottom but with tfs heads, systemax intake long tubes and Im going with andersons N-41 cam for now...I might put on a low psi blower like a paxton/powerdyne about 6-9 psi...I want to hit the 420/450 rwhp mark.
with your emissions, are you running the stock 4 cat h pipe or a two cated h pipe ?
stay away from powerdyne, they suck the internal belt breaks. and if you go with paxton, dont go with the old SN units that are ball driven (sn89,92,93,gss,sn2000), go with the new style. the NOVI
1991 Mustang GT
I had a sn89 and ended up selling it...Im in no hurry for the blower just to put my heads on, lol...
#18 | |
now im off to bigger and better things
#19 | |
Magnaflow 2.5 H with two cats which I don't think they make anymore. I'm in VA which has a thorough visual as well as tail pipe on the dyno but they are more lenient with replacement cats than CA is. Even with all of the mods and power, it passes with better readings than my bone stock 91.
#20 | |
1991 Mustang GT
Threads Similar to: 1988 LX Vortech
| Vortech V3: alternative A/W intercoolers to Vortech system? | saxmanJJ | 99-04 | 5 | November 3rd, 2011 02:58 PM |
| Pics of my Vortech - Need help from you Vortech guys!! | stanglifemike | 2005 - 2010 | 29 | September 12th, 2009 10:52 PM |
| Vortech & Cams OR Vortech & After/Intercooler | StuTheMusicEngineer | 99-04 | 21 | January 4th, 2009 10:51 PM |
| Looking at 1988 LX 5.0 | Mattd76 | 5.0 Mustangs | 26 | July 17th, 2008 10:45 PM |
| 1988 5.0 | FastBack71 | 5.0 Mustangs | 10 | January 18th, 2007 05:38 PM |
