N/a car...which cam to use??? - Page 2
Old January 12th, 2012, 04:34 PM   #21
ryanw's Avatar
1991 Ford Mustang GT
Originally Posted by ALEXLOPEZ62188 View Post
Hey Ryan, whered you get your cam?
I might get a custom grind when I add the S-trim..
Comp cams
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old January 18th, 2012, 10:37 PM   #22
OiDALE's Avatar
1991 Mustang GT
OiDALE is on a distinguished road
I know its not the best blower out but, Im getting a great deal on a PowerDyne BD11A. Dirt cheap...Its missing the crank pulley and some bolts. The guy said its for a 5.0 but not sure if the bracket are for a foxbody, he got it with a trade. (is there a difference between the 94-95 and fox brackets)?
What are you guys thoughts and or experience with this blower if any??? With my combo and pushing this blower at 6 maybe even 9 psi by changing the pulley size, what kind of power would I expect to see with the B-31 cam and my tfs and systemax? Would I be close to that 400-450rwhp?
Would I really need to get a tune or would I be ok to run an fmu and be safe at that psi? Would I need to add an MSD boost retard or 6AL box or what else would I need?
Old January 18th, 2012, 10:46 PM   #23
1992 Mustang LX
13.0 @ 105
StangBanger302 will become famous soon enough
Ive heard powerdynes are cheaply built...but with 6psi you should make at LEAST 420...if not, somethings wrong, lol. I would get an MSD 6AL cause of the Rev limiter and two-step but that's just me.
As I lay rubber down the street
I pray for traction I can keep
But if I spin, and begin to slide
Please dear God, protect my ride
Old January 18th, 2012, 10:47 PM   #24
1992 Mustang LX
13.0 @ 105
Oh, get a tune also...ive seen people not tune it and the block went **splitttttt** down the middle because it detonated.
Old January 18th, 2012, 10:49 PM   #25
ryanw's Avatar
Those blowers are internal belt driven, the only thing good about them is they run at a lower temp then others on the market, but your limited because its belt driven, so you cant spin them as high as the other gear driven superchargers. Go to there web page and it will tell you what the max rpm are
You may be replacing belts all the time... who knows.
255 fuel pump,
3:27 gears
Old January 19th, 2012, 05:03 PM   #26
UPR
Racerbox77's Avatar
1993 Cobra SVT
10.90 @ 128
Racerbox77 is on a distinguished road
Only buy it if its very very cheap, cause your gonna want more.
You should be higher than 450 if you can get 9 psi out of it.
FMU's are garbage. Buy bigger injectors (42 would be perfect for you).
Yes buy an MSD 6AL and a boost retard or the combo kit.
Lastly you're gonna want a wideband and set the timing at 12 degrees initial to start with the boost retard set at 1.5 . Colder plugs as well.
This should get you started without a dyno tune. Obviously you'll need 93 octane with this set up.
Run good gas and turn the boost retard to 0. Will make a big difference.
Just my thoughts from years wrenchin.
Runnin 10's with the A/C on
1993 Mustang Cobra Black on Black
2004 Focus SVT ZX5 1 OF 51 in Competition Orange
Soon to be supplying MM with UPR parts at stupid prices
Old January 19th, 2012, 05:24 PM   #27
ryanw's Avatar
I have a vortech boost retard, with fox body harness, so that no splicing needs to be done... plug and play.....it might be for sale if the price is right....lol
Like this http://www.vortechsuperchargers.com/product.php?p=69
http://www.vortechsuperchargers.com/...on.php?pvk=496
New.....togeather it would cost 348.90...ill let it go way cheaper, pm me if this is the route you go, other wise get the tune
255 fuel pump,
3:27 gears
Old January 20th, 2012, 10:57 PM   #28
OiDALE's Avatar
1991 Mustang GT
Thanks for all the input...Im still waiting on the guy at this point. I might pass on it if the brackets are for a 94-95.
