1991 Mustang GT
N/a car...which cam to use???
what would you say is the best cam for this setup as a "STREET CAR" no track time, Naturally asperated with spray??? not going to go custom as of yet! will change out the cam for future mods.
Low mileage Stock 302 bottom...170cc twisted wedges with either 1.6 or 1.7 roller rockers, Holley Systemax 2 with 2" spacer, 70mm TB, 75mm Egr Spacer, 80mm mac maf, 30# injectors, fender cold are intake, Mac long tubes 1 3/4 to 3" prochambers out 2 1/2 into flowmaster-side dumps and a set of 3.55 gears... |
1989 Black LX---Turbo
I run a stock 89 short block, Twisted Wedge 170's, with a Comp XE266HR cam, carburated, in my 82 Capri, and it runs outstanding. I drive it all the time in the summer, runs great, awsome power, idles away from a dead stop without any hesitation. I love this cam.
89 LX Black, Boss 331, C4,T76BB, FAST EFI 82 Capri RS,89 5.0 HO,Comp XE266,TW 170,T5,etc. 73 Dart Sport 340, 410ci Bracket Brawler 72 Demon 340 4-speed 1 of 1667 01 Ram Quad Cab 03 Grizzley 660 |
1991 Mustang GT
What size rockers? 1.6 or should I shoot for the 1.7's? plus and minus on both with that cam...?I also run with 3.55's what gears do you have?
With the XE266 I'd go with 1.6 ratio, because the cam already has .544/.555 lift. I've been running 3.73 gears.
![]() iTrader: 1 reviews
I just bought a custom cam 214/218 @ 50 565/555 1800-6000 rpm. We will see how it works out. I am going o run 1.7 rockers so it makes it 600/590 lift. Looks like I need new springs for my edelbrock heads!
02 GT- TF TB/ upper, flows, steeda triax, steeda UDP, BBK CAI, H&R SS springs, Steeda SFC, Poly bushings, AGX shocks/struts, MM CC plates, Steeda bump steer, Chrome Cobra R's, Rear control arm kit. |
1991 Mustang GT
That seems to be alot of lift on both of you guys cars...Im not sure but I think thats a bit much for MY setup especially running the 3.55's...?
Mustang Fanatic
1989 Mustang LX
Those long tubes are going to hurt your low end and midrange.
1 5/8 to a 2.5" collector... Tho for mild engines shorties work better. As for the cam, I'll have to agree with an xe266
89 Mustang LX: 347 AFR Comp Cam TFS Track Heat 359rwhp 395rwtq
89 GT
1991 Mustang GT
The long tubes are 1 3/4"...
Im leaning to either a Andeson N-41 or Comp XE274 maybe 276 but not sure how it will react with my 3.55's and T5. I do drive alot on the highway and spray on occasion but down the line will add a low psi blower. But for now I want a cam that would rip in the street but still have enough low with my gears with my systemax and TFS heads. But not sure which rockers to use 1.6 or 1.7's |
Mustang Fanatic
1989 Mustang LX
I fucked up. I meant a 1 5/8 would be a better choice.
Volumetric efficiency.* He's gonna want back pressure considering its still a stock 302 bottom end.
#11 | |||
1991 Mustang LX 5.0
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
Mustang Fanatic
1989 Mustang LX
Lol. Didn't see that he's gonna run nitrous. Nvm
1991 Mustang GT
So, After going back and forth on what I want out of this build I have come to the conclusion that I will sell off my nitrous kit I have and lean towards a blower instead "BUT," The blower will be bought LATER...about six months or so maybe even later.
That being said, the car is still a street car, stock bottom, TFS, Systemax, 1 3/4 Long Tubes and 3.55's...EXACTLY whats the difference in (hp and tq) between the n41 and b31 in either N/A or Blown??? Is there that much of a difference that would make me wish I went with one over the other after I installed it? I dont want to mill the heads for the N41 cam if they are straight, just want to keep compression stock but get as much power out of my sock botttom end. Second, After this long post (Again I really appreciate everyone that has read and gave there advice) I need to buy a cam that I will be happy with. I guess what I want is one that will work awesome N/A and hit my desired 450rwhp goal with the blower. That would make more sense right? Or, work good NA and Awsome with the blower??? BUT...Wouldnt dailing up more "PSI" on the blower make up the difference on the cam that would work Awsome N/A??? So which one.. |
1991 Mustang GT
ttt
1991 Ford Mustang GT
Becareful running a spacer on the holley sytemax, the ears of the upper intake are known to break, if you over tighten the bolts, i think holley doesnt recomend a spacer just for that reason....2 inches is a hell of a big spacer, i didnt even know they made them that big.
1969 Mustang Mach 1
6.824@101.61
Anderson n41.
./___ _ ____ ___ \. ( ]]] _ _ O _ _ [[[ ) \_ o _ _____ _ o _/ |___| ......... |___| http://www.youtube.com/watch?v=HyYU3...e_gdata_player |
1991 Mustang GT
Im going with the B-31...Brian At Anderson's really made my mind on it especially if my plans are to add a blower. Besides the difference N/A going with the N-41 over the B-31 is going to be around 10HP...Not really worth it if its going to perform much better with the B-31 Blown.
So that being said does anyone have a B-31 for sale??? |
1992 Mustang LX
13.0 @ 105
Corral
As I lay rubber down the street I pray for traction I can keep But if I spin, and begin to slide Please dear God, protect my ride |
Heres a copy of my cam card
SERIAL # M 8410-08 SPEC CARD # 13557708 SPEC CARD INQUIRY BY SERIAL # PART # 35-000-8 FW FORD 351W/302HO HR/SR CORE C35-8P FW FORD 302 H.O AUSTEMPERED Special Grind GRIND # FW 3016F/ 3035F HR13 DURATION @ .050 INTAKE 230 ROCKER ARM RATIO VALVE ADJ INTAKE .000 DURATION @ .050 EXHAUST 224 INTAKE 1.60 VALVE ADJ EXHAUST .000 LOBE LIFT INTAKE .3600 EXHAUST 1.60 VALVE LIFT INTAKE .576 LOBE LIFT EXHAUST .3530 VALVE LIFT EXHAUST .565 LOBE SEPARATION 113.0 DURATION .006 INTAKE C/L 111.0 TAPPET LIFT INTAKE 280 CAM ADVANCE 2 TAPPET LIFT EXHAUST 276 HYDRAULIC Y VALVE TIMING .050 OVERHEAD CAM N VALVE OPEN INTAKE 4 JOURNAL DIAMETER STD 2.036 VALVE OPEN EXHAUST 47 RECOMMEND VALVE SPRINGS VALVE CLOSED INTAKE 46 DEPARTMENT R VALVE CLOSED EXHAUST 3-
Mustang Fanatic
1989 Mustang LX
Hey Ryan, whered you get your cam?
I might get a custom grind when I add the S-trim..
