4 to 5 lug why?
Been searching multiple forums about this and I know the reactions will vary but bare with me.
Building an 89GT. Just throwing in a 331 nothing super powerful maybe 370-390 to the wheels from fordstrokers.com. Car is still 4 lug and will never see the track, just some horsing around and if done in time will make the power tour in 2012. I will convert the rear to disk but want the car to maintain originality. With all the above said are 5 lugs really needed for a car that will never see hard work? Can I get by just replacing the studs with upgraded ones? |
1986 lx notch
9.98 @ 135
The only reason to switch to 5 lugs is for more wheel choices. This is with stock axles and 4 lugs
![]() " Spending money I don't have.... on things I don't need .... to impress people I don't know " . |
1986 lx notch
9.98 @ 135
People switch to 5 lugs to gain a larger choice of wheels not for increased strenght.
1991 Ford Mustang GT
I was going to switch to 5 lug untill i saw the wheels that i wanted were made in 4 lug. and the wheels im getting are yours, i love them, and i dont see them to often, which i like ,so i wont be like every one else
1986 lx notch
9.98 @ 135
Dammit man ! The rodlites are my secret ! J/k I think they look awesome and you don't seem em too often. Good choice .
#7 | |
but when it come to the fronts not sure if i should get 15x8 or 15x7 wheel cuz i still want to run a 225 tire in the front. do you think a 225 tire on a 15x8 wheel will look alright ? or do you think that tire is to thin to run with that wide of a wheel ? i know it will still fit , but i just thinking about looks
1986 lx notch
9.98 @ 135
I can't remember what a 225 looks like on an 8 inch rim, sorry.
#9 | |
1995 Mustang GT vert
That should work. I can't recall what the width of my stock wheels are but they came stock with 225's all away around. I am now running 245's all around. Look great in back, the front is a bit overboard though. 225s should look fine in front.
1995 Mustang GT vert: STOCK, AODE (B&M shift kit), 2.73 gears, red leather, 410,000~ miles. 2007 Mustang GT: 4.6, 5-speed, 3.55 gears, black on black. (dads car) 1975 Camaro LT: 305ci, TH-350, weiand intake, 600cfm carb, 3.42 gears. |
1991 Mustang LX 5.0
About the only time where 5 lugs are better than 4 lugs for strength is for autocross. And it's because of sideways forces, as in push/pull on the studs. As far as spinning (circular) sheer forces, there isn't anything for you to worry about unless you're launching on 15" wide rims and slicks. And you won't find those in a 4 lug anyway, lol.
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
