no electrial power
I go to start my car today and there's no power to anything. My battery is charged and I have power at the solnoid, just nothing is coming on, no fuel pump lights or anything. It's a 89 gt
2003 Black Cobra. 2.3 whipple JLT RAI Dragon t/b 60s BAP Mafia Xcal3 MAC LTs w/ORX-pipe Borla stingers Billetflow IRS brace Eibach springs 1989 GT AFM b-31 cam crane springs 6.3 pushrods elec. W/P/fan 3:73s Manual steering tri-ax Shorties-orh-flows |
89 GT
Check your fusible links just past the solenoid. Sometimes they fail, or will corrode st the joints.
1991 Ford Mustang GT
Something simple you can check also is to make sure your positive terminal on the battery isn't arcing against the hood. I had that happen once. My battery had slid and started arcing and was causing me to have no power to anything.
I was stumped at first on why it was happening and then my wife actually noticed a small black spot on the hood where it looked like it had burnt. She had a good eye and noticed a little detail that I kept overlooking. It might not be this in your case but is worth checking. Otherwise if what fogged said isn't it I'd bet on it being a ground wire. |
The ground is good, I have it mounted in the trunk. What do these fuseable links look like?
about 3 inch off the stater solinoid you will see what looks like shrink wrap, and if you touch them they feel much harder then normal wire. there like a fuse. but in order to replace them you have to cut them out and either crimp or solder new ones in
But would that one fuse cause me not to have power to anything?
theres a lot of them, so im not positive but id say yes
there may be more then just at the soleniod, im just not sure where
So, i've checked power to my wires fuseable links are good and I have power at the ignition but still nothing will come on.?? I'm stumped Also when I have a wire that has power pireced the light will blink on the test light and it sounds like a blinker on, but there's not
2003 Black Cobra. 2.3 whipple JLT RAI Dragon t/b 60s BAP Mafia Xcal3 MAC LTs w/ORX-pipe Borla stingers Billetflow IRS brace Eibach springs 1989 GT AFM b-31 cam crane springs 6.3 pushrods elec. W/P/fan 3:73s Manual steering tri-ax Shorties-orh-flows Last edited by kratos2250; December 23rd, 2011 at 07:31 PM. |
Threads Similar to: no electrial power
| Need more power | 92'stang | 5.0 Mustangs | 2 | April 25th, 2011 01:32 PM |
| Is there a Brak kit to go from non power to power? | steelcityfan29 | Classic Mustangs | 15 | January 6th, 2011 03:57 PM |
| how much power can i expect with these upgrades?or what can i do for mad power? | muscletang420 | 99-04 | 34 | October 30th, 2010 10:54 AM |
| 1998 power window motor has power then installed its dead?? | crabbymaddy | V6 Mustangs | 2 | September 19th, 2010 07:26 PM |
| 5.0 more power | ModMotoMan | 5.0 Mustangs | 33 | March 26th, 2010 07:57 AM |
