Nitrous Kits??
Old December 21st, 2011, 12:58 AM   #1
TheBrat's Avatar
91 Mustang LX Fastback
We shall see when she gets done..
TheBrat is on a distinguished road
Nitrous Kits??
Alright so ive been thinking about going over to a nitrous kit for next season. Motor consists of...
Stock 86 Longblock
Edelbrock Intake
Edelbrock Carb
Tubular Headers
Its got a C4 trans in it also. Thinking about going with a cheap 2500-3200 stall convertor. What nitrous kits are there that will work with my Edelbrock carb? I see lots for Holleys. Max shot I would want to use would be a 150. Not looking for a big dollar kit, plan to boost it in future years. Also do I need a fancy nitrous convetor? New to the nitrous stuff.
Thanks...
Brett.
2003 MazdaSPEED Protege. Lava Orange with all the go fast parts
1991 LX. 2.3T in the works.
1977 Pinto Wagon. New motor combo in the works for 2012, C4, 4.10s, 150 pill. Et. unkown
1969 Impala. Needs a resto.
Im Canadian, Eh!
Old December 21st, 2011, 05:09 AM   #2
302Army187's Avatar
'89 LX 'Vert
10's or bust... Literally.
302Army187 has a spectacular aura about302Army187 has a spectacular aura about
I would recommend a nitrous converter as the car will act totally different on a non-nitrous converter.
on motor it would be nice and tight, but when you hit the nitrous, it would flash higher.
I recommend buying a used nitrous kit, and then a plate for your setup.
I will be selling two full nitrous kits, and you could buy a nitrous plate for your carb/intake for next to nothing on ebay.
you have any other pictures of your wagon? I have a soft spot for wagons, I daily drive a 1995 buick roadmaster wagon that one day I will put a turbo on.
also what's it run on motor?
H/C/I 302 + nitrous for now... supercharger/turbo soon?
www.youtube.com/Xarmy187
Please support my YouTube channel! My videos don't disappoint!
Old December 21st, 2011, 07:29 AM   #3
Hardon Enflooziast
98FireyGT!'s Avatar
'94 GT Vert
Havn't tried...
98FireyGT! is a glorious beacon of light98FireyGT! is a glorious beacon of light98FireyGT! is a glorious beacon of light98FireyGT! is a glorious beacon of light98FireyGT! is a glorious beacon of light
Send a message via MSN to 98FireyGT!
I used a dry-shot ebay setup that was designed for Hondas for a little while, then upgraded to a Zex kit for a few months. I added a window switch to the setup as well.
I ended up selling everything off though so I could put some money away for coil overs.
Bridget: 98 Mustang GT - PI Swapped, J-Mod and B&M Shifter...wrapped it around a tree sparing a deer - RIP
Sephie: 94 Mustang GT Vert - Full 03 cobra suspension and brakes, Magnaflow catback, K&N drop in filter, timed at 12*, SS brake lines,
Old December 21st, 2011, 02:45 PM   #4
TheBrat's Avatar
Thanks for the info guys, just finished talking to a friend of mine and im going to buy his new in box sniper kit for $300. Cant beat that price. Already may have tracked down a Convertor to. Everything on this car is BUDGET so we'll have to see.
As for what its ran (e.t), last time it was ran down the track was probably 5+ years ago and it was somewhere around the 12.90 Range. (Old owner) Consisted of 30x9 slicks (to tall) 3.08 gears, junkyard 302 with a 200'ish shot. Motor only had tubulars and a cheap carb and intake.
The new set-up is another junkyard pull with fresh gaskets, new oilpan, fancy Ford Racing Valve covers ( ) Edelbrock intake and carb, banged up gt-tubulars, NOS Sniper kit, C4 with stall convertor, HEI distibutor, and MSD wires, 4.10's, and hopefully a 275-60 radial. Car is pretty much gutted (though im putting and interior back in it). Hoping to run mid 12's for sure. Most expensive part of this build is the nitrous kit costing $300
12.9 run
Dog dishes and old slicks.
29x10.5W Slick. Stock suspension, stock wheel wells.
Motor in the car.
Brett.
Im Canadian, Eh!
Old December 22nd, 2011, 03:10 AM   #5
302Army187's Avatar
'89 LX 'Vert
Nice!
Body seems fairly strait for its year and all.
Are they unibody or body on frame? it seems to launch pretty good! also do you know the weight of the car currently?
What size shot are you planning? i would think a 150 would be plenty for your goals. Would love to see more as you go along!
Old December 22nd, 2011, 08:51 AM   #6
fogged306's Avatar
89 GT
Love the plate
Old December 22nd, 2011, 11:58 AM   #7
TheBrat's Avatar
Plate is no longer with the car, unfortunately.
Body is so-so. Car has tons of puddy in it though. Hopefully going to have the bodywork done in the spring. Also got my fingers crossed on getting a 12pt in it. Pintos are uni-bodies.
Already picked up my Sniper kit and have the plate and solenoids all set-up. Just have to wait for spring to install the bottle and wire it up.
Brett.
Im Canadian, Eh!
Old December 22nd, 2011, 01:37 PM   #8
TheBrat's Avatar
Going for bust! Between the crappy heads and bottom end play it should be fun. Heres from last night.
Thanks for the comments guys! Appreciate not getting chewed a new asshole since im in the foxbody section
Brett.
Im Canadian, Eh!
Old December 23rd, 2011, 12:52 AM   #9
1 Wheel Peel
GreenMustang00's Avatar
2000 Mustang 393w
2001 Mustang GT Vert
GreenMustang00 has a spectacular aura aboutGreenMustang00 has a spectacular aura aboutGreenMustang00 has a spectacular aura about
Brett.
I'm on this section daily. It's more about the motor than the body.
Good luck on the spray man! Just do it right the first time and dont cheap out
2000 393w Swapped Vert
2001 GT Vert
2002 Six Banger
Old December 23rd, 2011, 07:24 PM   #10
TheBrat's Avatar
Might look at another carb for it, dont really know that I like this Edelbrock 600. I have to run to tall of a carb spacer for the linkages to clear my valve covers. And im Trying to keep the height as low as possible.
As for weight. I have no idea what it weighs. Car has 2 buckets in it right now with no carpet or anything. Going to get carpet and a backseat in it this season though hopefully. Hope to be sitting around 3000#
Brett.
Im Canadian, Eh!
Old January 7th, 2012, 05:23 PM   #11
TheBrat's Avatar
Well all my motor stuff is sold and im going a whole different route. Didnt like my untested 302 and decided to sell it all since it owes me nothing. Looking to do a 347+ nitrous motor. Car should be in the 11's with no issues on the 150 jet.
Car from factory is supposed to weigh in right around 2650-2750#. With my in it im hoping to sit right around 3000. Not really sure if you guys are interested in this build, but figured id update you guys on the progress. Might start its own "build thread".
Brett.
Im Canadian, Eh!
Old January 7th, 2012, 05:30 PM   #12
termi_GT's Avatar
12.41@114
termi_GT has a spectacular aura abouttermi_GT has a spectacular aura about
Love the wagon.
MM FOBRA CLUB CO-FOUNDER
Old January 7th, 2012, 05:47 PM   #13
TheBrat's Avatar
Thanks man! Kind of in a toss up of a new motor or move out of my grandmothers basement... Decessions.. hahahaha
Brett.
Im Canadian, Eh!
Old January 7th, 2012, 08:23 PM   #14
1 Wheel Peel
2000 Mustang 393w
Throw a 9.5 deck in there. Much stronger block and more inches
2001 GT Vert
2002 Six Banger
Old January 7th, 2012, 08:29 PM   #15
69fastback's Avatar
1969 Mustang Mach 1
6.824@101.61
Ditch that pos Edelbrock carb.
./___ _ ____ ___ \.
( ]]] _ _ O _ _ [[[ )
\_ o _ _____ _ o _/
|___| ......... |___|
Old January 7th, 2012, 09:59 PM   #16
TheBrat's Avatar
Edelbrock is sold off. Sold it with the rest of my motor stuff. Bought a 750 billet bodied Demon. Ill have pictures of that in a couple days!
Brett.
Im Canadian, Eh!
Old January 9th, 2012, 04:58 AM   #17
302Army187's Avatar
'89 LX 'Vert
302 with decent heads and cam can ingest plenty of nitrous to blow the block.
H/C/I 302 with a 200 shot will be plenty to run 10's if you got the rest of the car set up right.
347 is wasted money IMO.....
Old January 9th, 2012, 01:37 PM   #18
TheBrat's Avatar
We have a few 347 cars around here. They make TONS of power. We got 2 foxs playing with a conservative tune running mid-high 8's in full street trim all steel except for the hoods. One car still has iron heads on it!
As for other purchases I should be getting a Mildon pan soon, also picking up an electric pump and regulator tomorrow probably.
Brett.
Im Canadian, Eh!
Old January 9th, 2012, 01:44 PM   #19
1 Wheel Peel
2000 Mustang 393w
Stock blocks?
2001 GT Vert
2002 Six Banger
Old January 9th, 2012, 01:48 PM   #20
1992 Mustang LX
13.0 @ 105
StangBanger302 will become famous soon enough
Those guys running 8s have aftermarket blocks though....and if you do an aftermarket block, get a dart and just go for a 363
As I lay rubber down the street
I pray for traction I can keep
But if I spin, and begin to slide
Please dear God, protect my ride
Threads Similar to: Nitrous Kits??
used nitrous kits 1_nice_03_gt 99-04 11 October 24th, 2011 08:42 AM
Nitrous kits papemilio V6 Mustangs 10 October 19th, 2010 04:40 PM
nitrous kits moosenuk17 99-04 37 February 8th, 2009 07:08 AM
tf nitrous kits Iownastang 5.0 Mustangs 0 June 2nd, 2008 12:46 AM
