1995 Mustang Gt
![]() iTrader: 1 reviews
Current Horsepower and Horsepower Goals For Your 5.0
Well seen this thread for the modulars so figured it would be fun for the ole pushrods.
Current Setup DSS 331 Block DSS Internals Trickflows heads Trickflow cam 24lb Injectors Pro-M MAF BBK shortys BBK CAI Horse Power - I have no idea New Setup (In process of build) DSS 331 Block DSS Internals Trickflows heads Trickflow cam 60lb Injectors C&L Blow Thru MAF 255lph Fuel Pump Boost Brothers Turbo kit (7-8lbs) Quarterhorse Tuner Horse Power Goal - 500rwhp
![]() 98 Cobra_stock bs/exhaust [SOLD] 2000 s/c gt, 511rwh 450rwtq [SOLD] 1995 331 Stroker Gt, (Turbo build in progress) - http://www.moddedmustangs.com/forums...-95-5-0-a.html |
1995 Mustang GT
![]() iTrader: 2 reviews
Current Setup:
BBK offroad x pipe JLT CAI 255 lph fuel pump Flowmaster Catback Horsepower: dont wanna know how slow it is lol New Setup: Trickflow heads Trickflow intake Trickflow cam 30lb injectors Pro M MAF Accufab 75mm tb SCT tune BBK longtube headers 1.6 roller rockers Horsepower: hopefully 320rwhp
95 GT: JLTcai, Flow40s, o/r Xpipe, lowering springs, cobra brakes, cobra rims, sbfc, shocks/struts, trickflow170 heads (1.6rr), cobra intake, custom cam, 75mm MAF, 75mmtb, bbk shorty headers, 24#injectors, 3.73 gears, mach 1 chin spoiler.
1991 Mustang LX 5.0
Current Setup
Stock Block 306 Budget internals w/forged pistons Trickflows 185 heads Trickflow Track intake Trickflow stage 2 cam Trickflow TFX nitrous plate for intake Accufab 75mm TB and spacer 30lb Injectors Abaco MAF MAC longtubes, pro chamber, and catback 3.5" cold air Underdrives Full MSD ignition Electric fan Horse Power - Hope to be about 400 at the crank on motor, but who knows for sure. Has a hundred shot jet in it to start, but haven't sprayed it yet. Next motor will be a 351 that is in my garage, the TF Box-R intake with n2o plate kit for it, and 90mm Accufab TB that I also have already. Will up it to 42lb injectors, get the appropriate headers and other misc swap parts, and the rest will stay the same.... May convert to E-85. I will up the nitrous shot considerably. And when that blows.... Final setup will be Dart 9.5 deck 427 on boost. Turbo or blower is still undecided. Won't stop until I hit 1200 horse. And hopefully that will keep me happy, cuz it gets crazy expensive after that. My buddy is working on an all new tube chassis car for himself that will boast a 2000 horse powerplant someday... I don't think I will be able to compete, lol.
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
1991 Ford Mustang GT
Current Setup
Dart block forged internals Eagle crank Eagle H beam rods probe dish pistons Internally balanced Stroked out to 331 ci custom cam AFR 185 heads---low compression for power adder 1.6rr trick flow R intake 30lb injectors 75mm pro m mass air meter 75mm egr spacer 70mm accufab TB K&N filter in stock air box canton 7qt oil pan spec clutch jba shorty headers 2 1/2'' x pipe with high flow cats 2 1/2" cat back with flowmaster super 10 mufflers stock T5 3:27 gears 255 lph fuel pump New set up will be PAXTON NOVI 2000 supercharger (unknown boost level at this time) 42-50 fuel injectors 3:73 rear gears subframe conectors torque boxes Horse Power goal 500rwhp
![]() DART 331ci stroker, AFR 185 heads, Trick Flow R intake, Accufab 70mm tb, 75mm pro m Maf, 30lb injectors, jba headers, 2 1/2" x pipe flowmaster super 10 mufflers, 255 fuel pump, 3:27 gears Last edited by ryanw; December 23rd, 2011 at 07:08 PM. |
1969 Mustang Mach 1
6.824@101.61
I'm hoping for 1 beeeeelion horsepower.
./___ _ ____ ___ \. ( ]]] _ _ O _ _ [[[ ) \_ o _ _____ _ o _/ |___| ......... |___| http://www.youtube.com/watch?v=HyYU3...e_gdata_player |
91 Mustang GT
1991 sliver GT
302 block with fly cut pistons
afr heads 185 sump oil pan tremic t56 with ram clutch cobra upper and lower both ported 255 walbro shorty headers meth injection vortech 15lbs Car made 403 on race gas with out meth
#7 | |
'89 LX 'Vert
10's or bust... Literally.
H/C/I 302 + nitrous for now... supercharger/turbo soon? ![]() |
2006 GT
11.99@114
Current set up.
Stock 302 throttle body to oil pan Stock headers BBK O/R H-Pipe Dumped Flowmaster 40’s 39# injectors 90MM Lightning MAF 255lph Walbro FP Anderson Power Pipe Vortech S-Trim @ 7PSI SCT Chip Dyno-tuned on 93 octane. 300RWHP/350RWTRQ Goal. H/C/I Similar to TF Track Heat top end kit (open to suggestions). 75mm throttle body. BBK Shorty headers (on shelf in garage). Dyno-tune HP#? If I don’t make 400rwhp. Swap to 10# pulley (on shelf in garage).
![]() 2006 GT (Fastest) 2004 COBRA (Faster) 1990 LX 5.0 (Fast) |
'89 LX 'Vert
you don't even need heads to hit 400rwhp, just get the vortech upto 15lbs on the stock heads.
that being said, almost ANY aftermarket cylinder head will make the power with ease. If it where me, get trickflow twisted wedge heads, stock cam, and a track heat intake, 10# pully should make OVER 400rwhp easy.
1992 Mustang LX
not done yet
honestly I have no clue what is in my motor at this point, but someday i want to be pushing 400hp, not much more because it is a convertable and I have this giant lead weight as a foot
92 Mustang LX 5.0 5 spd convertable, with Eagle alloy rims, custom exhaust with headers and custom driveshaft, MSD 01 Ford Ranger MODS: way to much time and money involved in this |
'89 LX 'Vert
1995 Mustang Gt
I dont see being a convertable would matter lol go all out!
1992 Mustang LX
not done yet
I've thought about it, but won't the car twist seeing as how it has no real roof support...I know with the 80s Monte Carlos t-tops you don't want to put much more then 500hp in with out reinforcing because they will fold like a taco
Sent from my HERO200 using AutoGuide.Com Free
91 Mustang GT
1991 sliver GT
thinking about taking it off. Im tired of my rear bumper catching of fire from unburt fuel.
Back right bumper ![]() back left bumper
#16 | |
1995 Mustang Gt
Weld a roof on and make it a notch back... Lol j/k
1990 Mustang GT
Had a stock 302, but pulled it to build a 347. Hoping to get at least 400 rwhp.
Sent from my SAMSUNG-SGH-I997 using AutoGuide App |
Proud American
I make zero now....
Planning on a steetable 800 horse to the tires with the new setup.
1994 splash
347
this is my new motor im installing into a ranger. its a hi comp motor.
Current Setup Coast High Performance Product Type Short Block Product Model Pro-Street Engine Displacement (cu.in.) 347 Engine Family FORD-LINCOLN-MERCURY - Small Block 302 Based V8 Engine Assembly Type Short Block Balanced Yes Engine Balance Type 28oz External Blueprinted Yes Engine Stroke (in) 3.400 Engine Bore (in) 4.030 Piston Manufacturer Probe Industries Piston Part Number 14112-030 Piston Material 2618-t61 Forged Aluminum Piston Top Type Dome Top Piston Head Volume (CC) +9.0cc Piston Compression Height (in) 1.175 Crankshaft Material Forged 4340 Steel Connecting Rod Length (in) 5.315 Connecting Rod Type H-Beam Steel Block Type Ford - 302 Roller heads pro comp 210 heads intake is a torker11 750 double pumper long tube headers 3 inch exhaust and bullet mufflers im hoping to run a low 11 1/4 |
Threads Similar to: Current Horsepower and Horsepower Goals For Your 5.0
| What's your current HP and what are your HP Goals? | bluesteve1 | Modular Mustangs | 16 | December 23rd, 2011 05:47 AM |
| horsepower | bluefilly | Pictures | 0 | November 4th, 2011 03:51 PM |
| 193 Horsepower From a 3.8? | DannyStu | V6 Mustangs | 46 | November 24th, 2007 07:25 PM |
| More horsepower ? | mexlatino | Modular Mustangs | 13 | August 28th, 2007 09:57 PM |
| Horsepower? | coltonrobertson | V6 Mustangs | 27 | August 27th, 2007 08:23 PM |
