Thermostat problem
Old December 21st, 2011, 11:18 PM   #1
Dknits782 is on a distinguished road
Thermostat problem
Hey so I decided to change my thermostat today came apart fine but when I went to put it back together some how I stripped the bottom bolt hole. I don't know what to do I can't fit a tap down there its to long, Any ideas would be great
Old December 22nd, 2011, 12:49 AM   #2
ryanw's Avatar
1991 Ford Mustang GT
I think your going to have to take the intake off and tap it or helicole it, but regardless that intakes coming off...from what i see when i look at mine
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old December 22nd, 2011, 01:55 AM   #3
Oh man I was hoping I didn't. Is that a difficult thing to do
Old December 22nd, 2011, 04:46 PM   #4
ryanw's Avatar
No not really, it just takes some time plus money for new gaskets. The main thing you have to worry about is an old rusted intake bolt breaking off and have to drill that one out to
255 fuel pump,
3:27 gears
Old December 22nd, 2011, 06:38 PM   #5
That's good news I have been reading some walk through and it seems manageable. Do u have a walk through that u recommend, and gasket wise should I all the ones they suggest for replacing lower and upper or just the main gaskets?
Old December 22nd, 2011, 10:29 PM   #6
1995 Mustang GT
Bubba95SN is on a distinguished road
Get the upper to lower and lower to heads. Tube of RTV(pick your color) to use where lower intake meets block. Gaskets that are used will fail.
Old December 22nd, 2011, 10:48 PM   #7
ryanw's Avatar
you have to take off the upper intake in order to take the lower off, so you will need all the gaskets
255 fuel pump,
3:27 gears
Old December 22nd, 2011, 11:43 PM   #8
Stdyhand is on a distinguished road
As mentioned it is not hard to do. As long as you don't mind getting your hands dirty it isn't rocket science. Just don't over tighten the bolts when you put them back in.
Old December 23rd, 2011, 12:20 AM   #9
Cool well I picked up a kit it has lower and uppper gasket and the distributor gasket, I also picked up a new thermostat gasket and silicon. I got a 3/8x16 tap and 3/8 x16 bolts is this all I will need?
Old December 23rd, 2011, 12:37 AM   #10
ryanw's Avatar
make sure you mark the position of the rotor and distributor or your timming will be way off when you put it back in
255 fuel pump,
3:27 gears
Old December 23rd, 2011, 01:04 AM   #11
Ok will do Im going to start tomorrow hopefully no snags
Threads Similar to: Thermostat problem
thermostat bobbyshelby 2005 - 2010 4 February 3rd, 2011 10:36 PM
Thermostat ajr1230 5.0 Mustangs 35 April 25th, 2010 11:21 PM
thermostat 93lx306dev 5.0 Mustangs 11 May 20th, 2008 12:42 AM
Thermostat Onemanzu V6 Mustangs 2 April 20th, 2007 07:00 PM
Thermostat??? PLease help.... ttop5.0 5.0 Mustangs 5 June 22nd, 2006 02:48 PM
