build on a budget help
Old December 22nd, 2011, 03:04 PM   #1
brandon444's Avatar
91 Mustang LX 5.0
brandon444 is on a distinguished road
I wanna start modding my motor but dont know where to start. i dont have much to spend so price is a factor.
my current setup is stock 5.0 from a 88, cold air intake, ac delete, electric fan, world class t-5, hurst short throw shifter, full exhaust
im sort of wanting to do something to the engine. gt40 heads, cam, or some other thing but like i said i dont know where to start with my budget
Old December 22nd, 2011, 03:12 PM   #2
98SnakeHorse's Avatar
1995 Mustang Gt
98SnakeHorse is on a distinguished road
Maybe find an upper and lower intake used?
Throttle bodies?
Better plug wires?
Sounds like you have the basic boltons out of the way.
I would suggest a nice set of gears, not sure your budget but that would be your next bang for the buck.
98 Cobra_stock bs/exhaust [SOLD]
2000 s/c gt, 511rwh 450rwtq [SOLD]
1995 331 Stroker Gt, (Turbo build in progress) - http://www.moddedmustangs.com/forums...-95-5-0-a.html
Old December 22nd, 2011, 03:15 PM   #3
brandon444's Avatar
91 Mustang LX 5.0
Throttle bodies?
Better plug wires?
forgot its got 3.73s already and I was thinking bout a throttle body just not sure what to get
Old December 22nd, 2011, 05:13 PM   #4
ryanw's Avatar
1991 Ford Mustang GT
Throttle bodys are pointless with stock intake and heads.
I'd do the hci. But if you only have money to buy one thing then I'd say tf heads . Forget about gt40 heads that's just a mild hp increase. And by the time you buy them and have them gone through you could have almost had enough money for the trick flow heads.
I'd do the intake after that. If you did the intake first you wouldn't see to much power from that do to the fact the the stock cylinder heads are more restrictive then the stock intake
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old December 23rd, 2011, 12:37 AM   #5
1 Wheel Peel
GreenMustang00's Avatar
2000 Mustang 393w
2001 Mustang GT Vert
GreenMustang00 has a spectacular aura aboutGreenMustang00 has a spectacular aura aboutGreenMustang00 has a spectacular aura about
For a budget you could get some of the following
Cobra intakes
GT40 intakes
Gt40p heads, like said by Ryan you wont see much gains, but they are cheap
Then a cam.
That is a good start I would think. Would be mild yet very streetable.
2000 393w Swapped Vert
2001 GT Vert
2002 Six Banger
Old December 23rd, 2011, 10:35 AM   #6
Digsj7's Avatar
1993 Mustang LX
my dog runs faster...
Digsj7 will become famous soon enough
Whats your budget?
CAI, GT40 Intake, GT40P heads, 1.72 RR, 70mm Accufab, UPR Control arms, Hedman Headers, Mac H-Pipe, Flows, Pro-5.0, 3.73 Gears, BBK caster/camber kit, Eibach springs, Subframe Connectors, 5 lug conversion,
MM+Cleavage Club Member #19
Threads Similar to: build on a budget help
Budget build Huggy General Tech 1 June 6th, 2011 02:44 PM
Budget Build Nitmare67 99-04 0 February 15th, 2011 04:24 PM
Budget 95 5.0 build. Bigballer460 94-95 18 September 11th, 2010 08:06 AM
Help me build a budget 2v DSG40TH2V 99-04 11 March 4th, 2009 11:13 PM
