1985 Mustang GT
Stock 85 ignition removal? MSD 6al questions
Im running an MSD 6al box and distributor. All the stock ignition is still sitting in the engine compartment, and when i tried unplugging it and taking it out the car won't turnover. What do i need to do to remove it?
I don't think my msd is wired correctly because it doesn't fire up until you let off the start position in the key. any ideas? |
Proud American
You should beable to just take it all out... You sure you arent taking a starter relay wire out?
Next MSD box needs a switched 12vs that stays hot while in the start position... Right now it sounds like its wired to only be on when the car has the igintion in the "run" postion, not the "start" postion...
1985 Mustang GT
it is wired to only be on in the start position... i was trying to rewire it into the stock ignition that had 12v in the "start" and "run" position...where is it wired that its only hot in "run"? i apologize but i got the car like this and the guy told me thats just how the MSD box worked, but i was suspicious
all i did was unplug the "duraspark ignition" module from the connectors and when i tried to start it again it wouldn't even roll over...where do i need to remove it in the wiring harness? any ideas? |
Threads Similar to: Stock 85 ignition removal? MSD 6al questions
| trans removal questions | 92ponylx | 5.0 Mustangs | 11 | November 27th, 2010 01:32 PM |
| Ignition Cylinder Removal | SteviGX | 99-04 | 12 | July 10th, 2008 10:53 PM |
| How much have you made on the stock ignition | fogged306 | 5.0 Mustangs | 5 | April 26th, 2008 06:07 AM |
| When should you upgrade stock ignition? | jtillery | 5.0 Mustangs | 4 | May 6th, 2007 05:59 PM |
| Stock ignition key | impetus | 2005 - 2010 | 17 | April 20th, 2007 02:33 PM |
