1989 Mustang GT
Copper vs. Aluminum heater core
So i had the dash down this weekend trying to find some electrical short behind the dashboard, and it seemed like the perfect time to change the heater core that had been bypassed quite a few years ago. I went to the Ford dealership, but they wanted $150 for the OEM copper heater core. Riebes wanted $30 for an aluminum one that did not have the support on the dog legged tube.
Is it worth getting the copper one, or should I go with the cheper aluminum one? which one will probably last longer, because I really don't want to have to tear the dash apart again anytime soon. |
91 Mustang GT
1991 sliver GT
$30 aluminum is the better bet. I just did mine a couple weeks ago.
[IMG] [/IMG]
1989 Mustang GT
any particular reason?
1991 Ford Mustang GT
id trust copper over aluminum but if copper is 130 bucks and the aluminum is 30 bucks, then id go with aluminum just for cost reason
1985 Mustang GT
How hard is it to change the speedo cable? do i have to tear the dash that far apart?
91 Mustang GT
1991 sliver GT
IF you take the cluster out the cable is right there the whole dash doesnt have to come out.
1991 Mustang LX 5.0
It's just a bitch to squeeze the speedo connector sometimes. If you have the new one to look at to see what to squeeze, it will make your life easier. Otherwise it's a cake job.
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
Threads Similar to: Copper vs. Aluminum heater core
| heater core Help please | tireshredder | Classic Mustangs | 9 | May 7th, 2011 09:50 AM |
| Heater cores - copper vs. aluminum | 99flGT | 99-04 | 14 | January 9th, 2011 07:13 PM |
| heater core... | 92hatchback | 5.0 Mustangs | 14 | May 8th, 2009 03:06 PM |
| Heater Core - Aluminum VS Copper/Brass | ChRis98GT | 96-98 | 1 | October 23rd, 2008 12:32 AM |
| copper or aluminum radiator? | Newtgadget | 5.0 Mustangs | 78 | October 22nd, 2007 08:09 PM |
