1990 mustang gt
Replace Heads BEFORE Upper Intake???
Im buying the BBK upper intake and 70mm throttle body outta AM. my question is, should i upgrade the heads before it? will much difference be made there. Not sure about these stock ones. dont know anything about them. Heard it will restrict power buy having the stock ones and will virtually be pointless to do the intake swap if i leave stock heads on....
many thanks. yur local 8 hampster stang
JUST 8 HAMPSTERS RUNNIN ON WHEELS.
1991 mustang 5.0
You're correct. You will gain a little power but heads and intake should both be done because they are both big restrictions on 5.0's. I would save my money if I were you. Or at least get a good intake that will give you room to grow. I have never heard one good think about those bbk intakes.
1991 Ford Mustang GT
Id skip the bbk intake. There are much better intake out there for the same or less money
1989 Black LX---Turbo
I'd spend your BBK intake money on a decent set of heads & top it with a mildly ported Explorer/GT40 intake and be way ahead of the game!
89 LX Black, Boss 331, C4,T76BB, FAST EFI 82 Capri RS,89 5.0 HO,Comp XE266,TW 170,T5,etc. 73 Dart Sport 340, 410ci Bracket Brawler 72 Demon 340 4-speed 1 of 1667 01 Ram Quad Cab 03 Grizzley 660 |
1990 mustang gt
also was looking into the tyfoon(sp?) upper. whats the word about some 351w heads ported and polished? seems like EVERYONE has gt40's now a days. but ofcourse there could be a reason behinde that. lol.
351 heads are nothing. And gt40 are okay but the same money your going to spend on them , you could have saved a few more bucks and bought a used set of trick flow or afr heads
If your going to spend the money, then save a little more and do it right the first time and in the end you'll save money because you didn't have to buy the same parts twice, not to mention labor cost if your not doing it your self
91 Mustang GT
1991 sliver GT
Im i the only one that likes the cobra upper and lower intakes? There supper cheap and flow well.
oh i liked my cobra intake, but every thing else was stock so i never felt any real power from it, but i can tell you that the ports on the cobra compaired to my new trick flow intake is a night and day difference, but ofcourse with out my after market AFR heads my intake would have been pointless
1990 mustang gt
finding descent heads these days on CL and EBAY is nothing but an uphill battle. (used)
if i spend the $500+ on heads alone it wont be at the least 3 months untill i can get the intake. im considering upgrading the TB for now and taking my money to other parts of the vechicle for now. Attepmt to save up the money to buy both; heads and intake, at the same time. good idea? or leave TB alone for now as well? now that i think about it, i do need a good set of drag radials..... lol
1995 Mustang GT
![]() iTrader: 2 reviews
go on the corral and you can find some really nice used heads and intake...just buy each piece when you get the money and put it on when you get everything...it would be pointless to put a tb on with stock maf and heads and all, wont gain barely any hp..like ryanw said, do it all right, the first time...its been a month and i almost have all of my parts and bought everything used from corral..might as well upgrade injectors while your at it dude..and get aluminum heads like trickflow and afr, you wont be disappointed..and the cobra intake is a good intake but there are better ones out there for not a lot more money
95 GT: JLTcai, Flow40s, o/r Xpipe, lowering springs, cobra brakes, cobra rims, sbfc, shocks/struts, trickflow170 heads (1.6rr), cobra intake, custom cam, 75mm MAF, 75mmtb, bbk shorty headers, 24#injectors, 3.73 gears, mach 1 chin spoiler.
1990 mustang gt
good lookin out people.
2008 Grabber GT500
2004 Mystic Cobra
I hope i don't offend anyone especially slow90 by asking this question but it seems like you guys know what your talking about. How much power will a 306 with a b-cam and explorer top end make? The heads just have a bowl job to accommodate the 1.850 int./1.550 ext. valves. Also I'm gonna run a sn95 70mm maf and have full Mac exhaust. That's it!
Thanks guys |
i wouldnt even bother upgrading just the TB...you will see ZIP in the horse power range...the tb is considered a SUPPORTING mod, meaning that if you dont upgrade other things first such as heads and intake, its pointless. the only reason to upgrade a TB at this point in your build is just for looks
1995 Mustang GT
yeah, the throttle body is just another piece of the puzzle when upgrading your heads and intake...are going to do a cam swap as well?
remember all of the other things you have to get also like: lifters, roller rockers, gaskets, and upgraded valve springs if you wanna splurge a little lol
#15 | |
91 Mustang GT
1991 sliver GT
Your faster than... Any STOCK civic other than a k20 Any evo without more than 18psi Any STI or Wrx But just to guess maybe 300hp or a little more depending on clutch and or drivetrain.
1993 Saleen
Wow. So much mis-information.
First off, do some research on that intake before you waste your money. Corral.net has had some extensive threads about the problems with them, up to and including a couple of cars burning to the ground due to the fuel rails leaking. I have never seen a car making any kind of power with a BBK. With stock heads, a big intake isn't going to do much. If you want to improve your power on a budget, an Explorer GT40 intake can be had for under $150. I did a Cobra intake (same as the Explorer) on my buddy's otherwise stock 88 Saleen. We did a before and after dyno on it. Stock it put 198 HP to the rear wheels. With nothing more than an intake swap, using the stock throttle body, it did 220 HP. More importantly, it improves the horsepower between 2000-4000 rpm even more than that, plus it lets the engine breathe up close to 5800 rpm versus running out of steam at 4500. For the price you're going to pay for the BBK piece, you could get an Explorer intake and a pair of good GT40P heads and be in the 240-250 HP range to the tires. As far as the 306 question, you say "Explorer top end". Are those worked GT40's from the Explorer or are they stock E7's with a little work? If they are E7's you're not making anywhere near 300. Probably more like 250. If they're GT40 heads, you're in the 270 range. Change out the heads for something that actually flows and you're probably in the low 300's.
1993 Saleen - Lightly modded 1993 LX 'vert - All the bolt-on's 1993 LX hatch - Stone stock, for now. |
#18 | |
Yes, you should upgrade the heads first, if you can't do it all at once. A big intake will choke off at the heads, but good heads can utilise or even increase air velocity from small intake runners. As Ryan said, you won't see much just upgrading the tb, its a mod that needs to support and be supported by other components, like the heads. More and more people want too much money for gt40 stuff considering what you get. The gt40 stuff is over rated as being good for the money and so people want more money because of the hype. Think about injectors and maf... Usually 19 and 24# injectors become weak points fast. You need bigger injectors to support more power. |
#19 | |
You want to go fast for cheap? Me too... ...it takes money, then it takes money because of the money, then it takes money Because. |
#20 | |
91 Mustang GT
1991 sliver GT
Threads Similar to: Replace Heads BEFORE Upper Intake???
| Gt40p heads and Upper intake...What else? | mustang416 | 94-95 | 1 | October 13th, 2010 05:32 PM |
| New heads with stock upper/lwer intake? | blakehunter316 | 5.0 Mustangs | 11 | October 11th, 2008 10:09 PM |
| Should I Replace My Upper Control Arm | Faulconer | 2005 - 2010 | 6 | June 13th, 2007 11:59 PM |
