88 Mustang Rearend Swap
I own a 88 mustang GT convertible, and I have found a rearend out of a 93 cobra. The cobra rearend has disk brakes and the owner installed 3.73 gear set. Before I purchase the rearend I have a few concerns and questions I was hoping you guys could help with. The cobra rearend is .75" wider on each side due to the axles, could I use my stock axles to keep the rear wheels from sticking out? I also know I have to replace the Master cylinder any idea what else would need to be replaced? Thanks for any help you can give me.
1991 Ford Mustang GT
im not sure but i think the cobra rear axles are 5 lug and yours is 4 lug
The cobra rearend is a 4lug
I stand corrected...Hmmm i wonder why it sticks out farther ?
the cobra axles are 3/4" longer, according to other mustang sites.
1991 Mustang LX 5.0
Maybe it's because of the disc brake setup. The SN rear's are 3/4 inch wider too.
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
^^^ i was thinking that to, but after i said i thought it was a 5 lug and i was wrong....i didnt want to be wrong twice in the same thread....lol
1991 Mustang LX 5.0
Only the Cobra R was 5 lug, lol. Actually a common mistake people make.
Threads Similar to: 88 Mustang Rearend Swap
| T-Lok vs Rearend Swap | DickWallace | V6 Mustangs | 27 | October 7th, 2011 03:42 PM |
| 7.5 to 8.8 rearend swap HELP | DickWallace | V6 Mustangs | 12 | September 9th, 2011 11:28 PM |
| rearend swap? | goatboy | 5.0 Mustangs | 3 | August 5th, 2011 08:53 AM |
| Rearend swap | 01V8MUSTANG | 99-04 | 10 | November 24th, 2009 01:17 PM |
| 8.8 rearend swap | Caddpro | 5.0 Mustangs | 22 | February 16th, 2008 07:15 PM |
