Ball Joint Time..
So im pretty sure the passenger side ball joint is goin out, there is a decent amount of play in the right wheel, when its parked, i can grip the rim with my hand and turn it back wards and forward maybe 3 Thousands of an inch..
has anyone tackled the ball joint yet? Best methods? or just let a shop do it, lol getting the parts is no big deal but ive heard horror story about trying to tackle it even from ASE cert techs... ?
89 Mustang lx 5.0 11.5 Compression Edlebrock 150 dry kit 1.70 0-60ft 11.20 @124 |
Pretty simple as long as you have a ball joint press. if it is a press in joint
couple hours to do both
1969 Early Bronco 3.5" lift 37" swampers 1969 Early Bronco 2" lift half cab 1979 2.3t Cobra 1997 Black Cobra http://www.cardomain.com/ride/680999 http://www.myspace.com/beheivjer |
I am not a front end man, but I believe that if you can move your tire left and right (as if turning) then the problem is not ball joints, it could be tie rod ends, steering box, etc... That is if I read your post correctly. Every time the front end man checks ball joints, he/she lifts the wheel and puts a pry bar under it to check for play. Just my observations.
jpalm |
Ford does not recommend replacing them at all. You should just replace the entire lower control arm. Its easy and no bad priced. I got both side LCA with ball joints from ford new for $175 a few years back.
you might want to check you wheel bearings in the hub, before you even woory about that. worn wheel bearings can cause a lot of play.
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
Threads Similar to: Ball Joint Time..
| Best fast food joint | WAR-PARTY | The Clubhouse | 35 | September 13th, 2007 10:00 PM |
| limit heims joint movement | beheivjer | General Tech | 3 | September 12th, 2007 12:10 AM |
| Won't see this on the telle: smoking a joint | WAR-PARTY | The Clubhouse | 6 | July 11th, 2007 06:41 PM |
| u joint | mustangrebuilder | Classic Mustangs | 1 | March 26th, 2007 09:55 AM |
| u joint | quicksix | 5.0 Mustangs | 3 | January 2nd, 2007 08:55 PM |
