Questions about new car!
Old June 4th, 2007, 10:03 AM   #1
Blown93Cobra is on a distinguished road
Here is the background:
I just purchased a heavily modded '93 Cobra. I intended to have it as a weekend driver/show car/friday night racer at the local dragstrip. However, it's a bit more than I bargained for so far. Here is the list of mods on the car.
DSS 331 c.i. long block w/ forged internals
Vortec blower
AFR heads
Radical Cam
Ported upper and lower intake
70mm TB
MSD ignition and coil
60 lb/hr injectors
Dual fuel pumps
BBK long tubes w/ BBK H-pipe w/ hi-flow cats
MAC 2 1/2" cat-back
4.10 gears
HD clutch (crazy hard to push in)
Dyno's @ 545 hp
Here's my issues so far, while driving it home after picking it up, (about an hour or so into the drive) I am coming to a light in 4th gear, instead of down shifting, I throw it in neutral and coast to the light, as I get to the light, the car seems to surge a bit from about 1.5k RPM to 3k RPM and then stalls on me.
Question: Is this due to the duel fuel pumps, injectors, or cam?
Question: Do I simply need a re-tune on a dyno?
Another issue, the cars runs extremely hot, Autometer temp gauge runs consitently at 200 to 205 while doing 40 mph, but, if I'm in stop & go traffic it creeps up to 225 to 230 degrees.
Question: Do I need a new thermostat, better fans, and/or radiator?
Any suggestions would be greatly appreciated!
Thanks
'93 Cobra
DSS 331 longblock, AFR heads, cam, Ported upper & lower intake, 70mm TB, Vortec blower, exhaust, gears, Dyno'd @ 545 hp
Old June 4th, 2007, 12:41 PM   #2
Wow.... can anyone help out there?
'93 Cobra
Old June 4th, 2007, 12:45 PM   #3
HMUSN's Avatar
iTrader: 9 reviews
sounds dumb but are you running a stock radiator ?
Old June 4th, 2007, 02:07 PM   #4
IcantDo55 is on a distinguished road
MORE INFO?
What blower?
What rib belt?
What rad?
What tem stat is in there?
Whats base timing @?
What tuner, is there any?
-Mike
Link to My Site
Want to Play Some Pool???
Stroked and Blown!
Old June 4th, 2007, 03:27 PM   #5
3 row radiator
'93 Cobra
Old June 4th, 2007, 03:31 PM   #6
Originally Posted by IcantDo55
MORE INFO?
What blower?
What rib belt?
What rad?
Vortech V-2 SQ S-Trim HO Blower w/ powercooler
Not sure what rib belt
3 row rad., (brand?)
Not sure on the thermostat
Again, timing #'s?
Dyno was done by previous owner at Precision Dyno
'93 Cobra
Old June 4th, 2007, 04:45 PM   #7
MORE INFO?
What blower?
What rib belt?
What rad?
Again, timing #'s?
You have to find out what thermostat and and fan you have it could be the problem. The rib belt is an issue with fitting a fan. 8-10 rib belts force you to use a small fan that uasually do not work well enough. What tuner...AEM, FAST, CHIP.....ya know so we can see how the timing curve is done. Some guys make the curve to aggressive causing heat issues.
-Mike
Link to My Site
Stroked and Blown!
Threads Similar to: Questions about new car!
New here got a few questions JonnyB 5.0 Mustangs 17 August 19th, 2010 01:39 PM
Few Questions Bies08 V6 Mustangs 12 August 21st, 2007 11:33 PM
rim questions SilverGT04 99-04 26 August 17th, 2007 02:54 AM
*a few questions* mustang1072 V6 Mustangs 10 June 29th, 2007 12:59 AM
2 Questions mikethetigerrr V6 Mustangs 21 October 25th, 2006 10:23 AM
