96 f-150 5.0
Old December 30th, 2011, 10:53 PM   #1
Look Ma! My First Post!
96f150 is on a distinguished road
96 f-150 5.0
I know this is a mustang site, but I figured who knows the ford 5.0 better then the mustang guys. I just bought a 96 f-150 with a 5.0, 5 speed standard. It starts great cold and great when it is hot up to a couple min after you shut it off. If I let it sit 10 minutes it starts harder and if it sits 30 min it prob cranks for 5-10 seconds and then puffs black. I changed out the coolant temp sensor for the ecm, no difference. I I checked the fuel pressure with the engine cold it is 38 psi and 34 psi while running. The fuel psi does slowly bleed off after i turn the truck off, is there a rule of thumb for time engine is off to the amount of pressure that cam bleed off? Any Ideas?
Old December 31st, 2011, 01:52 AM   #2
FastStang91Lx's Avatar
1991 Mustang LX 5.0
Black smoke is excess fuel. I would change the air intake temp sensor also.
