adjusting the 1.7rr
Old December 31st, 2011, 04:38 AM   #1
1990 ford mustang GT
bennyjet846 is on a distinguished road
adjusting the 1.7rr
i have a set of the comp cams 1.7rr on my gt40 heads, stock cams. how do i go about adjusting the roller rockers for the most performance? thanks
Old December 31st, 2011, 08:00 AM   #2
FastStang91Lx's Avatar
1991 Mustang LX 5.0
Are they the stock style pedestal mount? If so, then you torque them down and you're done.
Old December 31st, 2011, 11:27 AM   #3
1992 Mustang LX
13.0 @ 105
StangBanger302 will become famous soon enough
BENNYJET, YOU HAVE ONE CAM...ONE!!! Now that I'm done yelling, yeah, torque em and go. No need for adjustments like stud mount shit.
As I lay rubber down the street
I pray for traction I can keep
But if I spin, and begin to slide
Please dear God, protect my ride
Old December 31st, 2011, 01:21 PM   #4
lol i don't know why i keep saying Cams. i always mean to say Cam. when i got them off someone, each RR were set differently, the adjuster piece that where the pushrod piece sits. i adjusted them so they are all the same. but yea, i'm just gonna bolt and go
Old December 31st, 2011, 01:32 PM   #5
horsepowerjunkie's Avatar
1989 Black LX---Turbo
horsepowerjunkie will become famous soon enoughhorsepowerjunkie will become famous soon enough
Benny, you have the Comp Cams adjustable pedistal mount roller rockers. Each rocker has an adjustment screw in the pushrod hole, they must be adjusted for your engine! The way I do this is to get each cam lobe on the base circle. I start with the first rocker on the driver side and work to the back, then do the other side the same. Turn the crank until the first rocker stops moving/lifting, then turn the crank 1 full turn. You are now ready to adjust that rocker. Turn the adjuster screw until the lifter plunger starts to move downward, then turn another half a turn & tighten the lock nut. Do every lobe like that and you should be set. This should be done with the intake off, or else you're not going to see the lifter start to plunge.
89 LX Black, Boss 331, C4,T76BB, FAST EFI
82 Capri RS,89 5.0 HO,Comp XE266,TW 170,T5,etc.
73 Dart Sport 340, 410ci Bracket Brawler
72 Demon 340 4-speed 1 of 1667
01 Ram Quad Cab
03 Grizzley 660
Old January 1st, 2012, 03:11 AM   #6
oh crap, everything is back together. i haven't started yet though. i should be ok to run it like that for awhile?
Old January 1st, 2012, 07:43 PM   #7
ryanw's Avatar
1991 Ford Mustang GT
id ajust them before running if those are the rockers you have, you dont want to burn up a lifter...
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old January 1st, 2012, 09:00 PM   #8
1991 Mustang LX 5.0
If too tight, you'll leave valves hanging open.
Old January 3rd, 2012, 01:59 AM   #9
thanks for the feedback guys. yea i took it apart and adjusted them. i have to admit, it was WAY out of adjustment. i had that lifter plunger way in there. the only crappy part was 2 of the roller rockers i had a hard time adjusting. when i adjusted it, it was moving the the roller rocker instead of the plunger. any thoughts why it was doing that? i
Threads Similar to: adjusting the 1.7rr
adjusting timing saleen73 99-04 2 June 27th, 2008 03:48 PM
Adjusting to the T-56 OcOnnor220 99-04 5 April 16th, 2008 11:51 AM
Adjusting the clutch....help? lwhitetrash88l V6 Mustangs 11 April 14th, 2008 07:13 PM
adjusting headlights Stang187 Visual 4 February 18th, 2008 08:25 AM
Adjusting the TPS. Casper98GT Modular Mustangs 2 September 26th, 2007 05:53 AM
